Direct Vent Propane Furnace + Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 07:36 PM   #1
011010100110111101100101
Rewards Points: 160
Direct vent propane furnace + water heater
I'm no plumber, or HVAC tech. That is my disclaimer.
I'm installing a direct vent propane furnace. You know, the PVC out the wall type.
I'd also like a propane water heater. Can I tie a direct-vent (forced draft) water heater to the same vent pipe through the wall as the furnace, or no?
I don't want a million wall or roof penetrations.
-- Joe
anesthes is offline   Reply With Quote
Old 01-16-2012, 07:59 PM   #2
MarginallyQualified
Rewards Points: 2,464
You have that backwards... Direct vent means a HOT metal flue pipe directly connected to the source of that heat... whether that goes out a wall or roof.
Can I tie (the flue of a gas burning appliance) to the same vent pipe (of another gas burning appliance) or no?
No. (There's a long sorta, maybe sometimes answer too... but it really doesn't apply here.)
How about just two?
Old 01-16-2012, 09:09 PM   #3
An old Tradesmen
Rewards Points: 6,870
No it doesn't. Direct vent can be PVC, or metal vent, depending if its Class I, II, III, or IV.
How about just two?
OP. No you can't use the same vent pipe. it would effect the pressure switch of the unit that isn't running, and cause you no heat, and no hot water problems.
Old 01-16-2012, 09:49 PM   #4
Rewards Points: 160
Hrmm. It says "direct vent" yet the manual says use PVC, and that it has a blower. (picture attached). ??
-- Joe
Old 01-16-2012, 09:54 PM   #5
Rewards Points: 160
I see. Oh well. Guess it will be 3 holes.
-- Joe
Old 01-17-2012, 04:11 AM   #6
An old Tradesmen
You can use a concentric vent for the furnace. Its a larger hole, but only one hole for the furnace, and one for the water heater then.
Old 01-17-2012, 08:58 AM   #7
MarginallyQualified
At what point does the term POWERED get removed from the rest of the venting (and combustion) description?
Old 01-17-2012, 09:27 AM   #8
Rewards Points: 160
Is that a question for me or the mfg ?
-- Joe
Old 01-17-2012, 09:41 AM   #9
MarginallyQualified
LOL nah, I was just 'venting' I suppose.
Old 01-17-2012, 04:56 PM   #10
An old Tradesmen
The term "power venter" is sometimes used on some direct vent units. Basically, all direct vent units have a "power venter". But not all "power venters" are direct vent. You can add a "power venter" to an 80% furnace, and side wall vent it. but the vent must be metal then.
Inducer.
Blower.
Power Venter.
Old 01-17-2012, 05:32 PM   #11
Rewards Points: 160
Inducer.
Blower.
Power Venter.
Learn something new every day. This furnace is 93.8% efficient. It's a propane unit. I bought the furnace, as well as the ac unit. Now I just need to learn how to properly install the ductwork. Perhaps I can pick up a book and get educated.
Thanks guys.
-- Joe
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
vent size for 40 gal gas water heater amakarevic HVAC 10 10-19-2011 06:15 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 12:34 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
