Direct Burner Ignition Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 12:15 PM   #1
Direct burner ignition valve
Can someone tell me the sequence of events that happens insdie this valve once gas gets into it. Thanks
ams777 is offline   Reply With Quote
Old 02-17-2012, 03:03 PM   #2
how
Rewards Points: 1,104
The gas is usually always "in" the valve.
The gas is stopped or allowed to pass through the valve to the burners by internal 24V solinoids powered by the board and monitered via a main burner flame sensor system. The gas also passes through a regulater in the valve to reduce the gas pressure from the supply side to the output.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (02-17-2012)
Old 02-17-2012, 03:34 PM   #3
REP
If you are talking about a direct ignition system then a spark is generated by the ignition box and a micro current is sent back to the box sometimes via a body ground.This keeps the 24 volts on the valve until the stat sees the set temp reached.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Bad elec. solenoid on top of furnace gas valve with spark ignition jerrybrumley HVAC 5 11-19-2011 08:16 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Exhaust fan with no Burner Ignition routine Turtle learner HVAC 1 12-22-2009 10:08 PM
Gas valve on a bryant heavyduty HVAC 1 12-16-2009 08:42 AM
