-   -   Dip switch setting on Carrier Infinity 96 Furnace (http://www.diychatroom.com/f17/dip-switch-setting-carrier-infinity-96-furnace-166035/)
jeepgrady 12-09-2012 01:51 PM
I have a new home with a dual fuel Carrier system. The system is controlled by a Carrier Comfort Zone II Control board.
The furnace model 59TN6A control board has various dip switches to set up the system. One of the switches,(SW1-4) is titled" Comfort/Efficiency Adjustment". The manual says that the Normal position should be ON. The Description of use says: "Turn on to decrease low heat airflow by 7%, and high heat airflow 10% for maximum comfort.
My switch is set to off. From what I understand, the Comfort Zone controller adjusts everything automatically. So my question is: should this switch be set to off or on, and what are the advantages, one way or the other?
danpik 12-09-2012 03:57 PM
Posting duplicate posts two min apart wil not solicit an answer any faster. All of the members here are "volunteers" in a sense. If someone is familiar with this system I am sure they will answer when they read this. Please be patient.
jeepgrady 12-09-2012 05:58 PM
Take it easy. It wasn't intentional. My browser wasn't responding.
beenthere 12-10-2012 04:27 AM
Set to on. You have warmer air from your registers, which tends to make people feel warmer then when the air is coming out cooler on cold days. Set to off, the air flow is higher, and youi get a bit more efficiency from it.
Set to on. You have warmer air from your registers, which tends to make people feel warmer then when the air is coming out cooler on cold days. Set to off, the air flow is higher, and you get a bit more efficiency from it.
jeepgrady 12-10-2012 09:52 AM
Thanks for the double response, Been There, LOL.
One more question. I discovered looking at the instructions for the zone control that there is a similar setting in the stat. Should the stat also have the comfort setting enabled, or does the stat dictate the settings and thus the furnace dip switch should be off?
Technow 12-10-2012 10:41 AM
You have an infinity furnace which would work well with the infinity zone controller and no dipswitch settings required and you can control everything from the stat????
What is your outdoor unit?
jeepgrady 12-10-2012 10:48 AM
The zone control is not Infinity. It is a Carrierr Comfort Zone II controller. The out door unit is a Carrier performance HP model # 25HCB6.
Technow 12-10-2012 11:01 AM
I know...why didn't you get the infinity controls?
jeepgrady 12-10-2012 11:13 AM
It's a new home. I upgraded my system from the standard builders grade. Since I'm in NE Pa. the system is mainly designed for heating. The HVAC contractor suggested this set-up. I questioned about the Infinity controller and he stated that the CZII was sufficient enough for my needs. Seems to work well. No complaints.
Can you answer my question about whether the dip switch setting on the furnace should be set to off and the stat set to comfort, or should both the furnace and stat be set up for comfort?
Thanks.
Technow 12-10-2012 11:45 AM
Thanks.
Beenthere did that.
jeepgrady 12-10-2012 11:59 AM
Been there answered my original question about the furnace. Then I discovered a similar setting on the stat. Should they both be set to comfort?
Technow 12-10-2012 12:49 PM
You never have said what thermostat you have
jeepgrady 12-10-2012 01:02 PM
Comfort zone II controller and stat.
Technow 12-10-2012 01:57 PM
I don't think the new furnace works with the logic of the older zoning panel, I couldn't find any reference that the new furnace will respond to that function. someone else may know:(
