Digital Thermostat To Control Exhaust Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 01:34 AM   #1
Question
Digital Thermostat to control exhaust fan
I've procured a digital thermostat that i'd like to use to activate a 240Vac ceiling exhaust fan at a given temperature.
The Manual for the Thermo states;
Features:
  • 3 high speed air blowers.
  • Motorised valve with electrically operated wind valve.
  • Cotrol ventilation, cooling, warming.
Tech. specs:
  • Supply voltage 220VAC+/- 10%
  • Relay electronic contact 3A 240VAC
  • Output 200W
...and the wiring diagram shows its 6 terminals labled; N, HI, MID, LOW, VALVE, L.
Now for my questions;
  • do the high, mid, low, fan settings correspond to different speeds for a single fan or to switching for 3 individual fans?
  • Could this thermostat be used to activate and vary the speed of a speed variable ceiling fan? (if so, how would it be wired to this unit?)
...sorry but i don't know how to include the actual wiring diagram in this thread. Perhaps the info I've given you guys might be enough, otherwise the actual diagram can be downloaded at http://downloads.villageorigin.com/001480-144/
To anyone who might shed some light ... my thanks!
SmokinSparkie is offline   Reply With Quote
Adding a Digital Thermostat lostdog HVAC 4 09-01-2010 04:11 AM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 HVAC 4 06-02-2008 03:44 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 11:52 AM
