Different Elbows On Baseboard - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 07:02 AM   #1
Rewards Points: 346
Different Elbows on baseboard
I noticed that my upstairs has these different elbows on the FHW baseboard heating. I have never seen these, but all the baseboards upstairs have these. What are they for??
dougp23 is offline   Reply With Quote
Old 11-22-2011, 07:43 AM   #2
Rewards Points: 380
Air vents built into elbow. Loosen screw at top and air will come out, if there is air trapped in that part of the system. Don't loosen too much, or you may get wet.
HVACDave is offline   Reply With Quote
The Following User Says Thank You to HVACDave For This Useful Post:
dougp23 (11-22-2011)
Old 11-22-2011, 07:53 AM   #3
Rewards Points: 346
Ahh! A lot of banging noise when the heat runs, but whoever installed this didn't allow much expansion room. The holes for the pipe are just big enough for the pipe, so maybe it's air making that noise, or maybe it's the lack of expansion room. I will try letting some air out!
Old 11-22-2011, 08:13 AM   #4
Lol don't let them unthread completely from the holes unless you have lots of towels handy.
Evstarr is offline   Reply With Quote
Old 11-23-2011, 11:56 AM   #5
REP
Air in a hot water system usually migrate to the upper levels.If you are going to have air in the system it will be located in the upper level radiation.
If you have or you install a Spirithern air scoop in the basement,you will no longer need to bleed.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
ben's plumbing (11-23-2011)
Threaded Elbows mtk369 Plumbing 6 02-17-2011 08:26 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
