Difference In Temperatures At Registers - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 11:49 AM   #1
Difference in temperatures at registers
My Freedom 90 seems to be functioning properly in my Bi-Level Split 1200sq' home, however I have a significant difference in temperatures at all my registers. The lower Level blows at 118'F, the middle level blows at 65'F and the upper level blows at 95'F. The ducts were cleaned a few months ago and a fresh filter recently installed. The furnace does however seem to be running very often and for short periods of time. Thoughts anyone?
moe975 is offline   Reply With Quote
Old 01-04-2012, 12:18 PM   #2
In a split level register temps are seldom equal out all registers. But 65* is drastic.
You say the furnace is running for short, frequent cycles.
How new is the furnace?
My first guess would be that the flame sensor is dirty and cutting off the burners before a complete cycle is finished.
Also the heat anticapator could be set too low.
How old is the furnace? And how many BTUs is it?
how long has this been going on?
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
moe975 (01-04-2012)
Old 01-04-2012, 08:55 PM   #3
My apologies the furnace is actually a Freedom 95. It is a 100,000BTU and it's 3 years old. This issue only started this winter.
Old 01-05-2012, 03:29 AM   #4
An old Tradesmen
Rewards Points: 8,236
Because its over sized, it doesn't run long enough to get all the ducts warmed up.
The Following User Says Thank You to beenthere For This Useful Post:
moe975 (01-05-2012)
Old 01-05-2012, 10:06 AM   #5
Been is right...waaayy to big a furnace. You should have more like 60 to 70KBTU depending on you windows and insulation.
Who the sam hill sized that furnace for you...Ray Charles?
Old 01-05-2012, 05:28 PM   #6
Thanks folks for the information but I guess I should mention that I live in Northern Alberta, Canada so the climate is fairly cold here. Despite the BTU's of the furnace this is my 3rd winter so why would I only now have this issue? Regardless I will clean my flame switch this weekend and give that a try. If that does not help any suggestion, other replacing the furnace?
Old 01-05-2012, 06:10 PM   #7
An old Tradesmen
So it heated your house evenly before this year?
Old 01-05-2012, 06:23 PM   #8
Yes. Actually the first 2 years it cycled on almost as often but we had generally equal temperature throughout the entire home.
Old 01-05-2012, 06:36 PM   #9
Rewards Points: 582
iwould time the cycle of the furnace with the burners on and see how long it runs..an take note of what happens through cycle......has the thermostat been changed ...????
Old 01-05-2012, 06:43 PM   #10
I will certainly take note off all that and post it for all to view. As for the thermostat, it was installed when the furnace was.
The Following User Says Thank You to moe975 For This Useful Post:
ben's plumbing (01-05-2012)
Old 01-05-2012, 08:45 PM   #11
Missouri Bound's Avatar
Any vents open on the outside of the house...loose siding or missing insulation...something that just happened? Any chance that duct supplying the 65 degree air is now exposed to outside air? What has changed? Is the airflow still the same?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Adding to registers to existing hvac system amugable HVAC 2 07-22-2011 06:07 PM
Heat Registers: stamped vs.adjustable joside HVAC 0 11-10-2010 01:59 PM
mold found on registers deerhunter HVAC 0 09-27-2010 07:38 PM
Adding heat registers to basement brick1930 HVAC 0 08-24-2009 05:52 PM
Baseboard moulding taller than air registers interplexr Remodeling 8 04-03-2009 06:24 AM
