Diesel Smell In House - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 09:20 PM   #1
I have a Bock oil fired hot water heater in the same room as the oil fired furnace / heat exchanger. I've noticed when the A/C was on, or the heat is on, and the water heater is running, my house occasionally smells like a truck is idling outside. I have also noticed that the "plug" for the inspection port to the firebox on the water heater keeps falling out.
I had some tree limbs overhanging the chimney, so I cut those back. I taped all of the joints on the metal piping with foil tape. Each of these has helped a little bit, but I still have the smell periodically. The oil company said I need a chimney company to check my flue. Of course this is the busy season... while I wait for my appointment to come up, is there anything I can check on my own?
Thank you!
mikeatrpi is offline   Reply With Quote
Old 10-26-2010, 06:00 AM   #2
An old Tradesmen
Rewards Points: 6,148
Open all doors leading to that room. And see if you get the smell then. If not. then that room doesn't have enough combustion air. And a combustion air vent should be added.
Old 10-26-2010, 08:03 AM   #3
I have a fresh air vent - the room is in the basement, and one of the basement windows has been replaced with a screen and ducting leading to the floor of the room.
Is it a clue, or coincidence, that the inspection plug keeps falling out? Can I fix that?
Thanks for the tips!
Old 10-26-2010, 08:36 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,172
It may be backfiring/delayed ignition on startup and blowing the plug and fumes out. Need to have an experienced oil tech service it/set it up with a combustion analyzer etc.
Old 10-26-2010, 05:59 PM   #5
An old Tradesmen
As Yuri said. Could be a delayed ignition problem.
Not something to take lightly.
Old 10-26-2010, 06:47 PM   #6
Hvac Pro
yuri's Avatar
It will only get worse and more expensive $$ to repair. Oil improperly burnt can produce CO Carbon monoxide.
Old 10-26-2010, 07:12 PM   #7
" Euro " electrician
frenchelectrican's Avatar
I agree with those guys get HVAC tech guy come out and check it out It is delayed ingtion and this is very serious matter to take care of it. ( A HVAC tech will have to check the combustion chamber to see any damage there )
I allready went thru few time myself { I am allready qualifed to deal with this }
And have the HVAC guy replace the nozzle tip as well { that should be done every year anyway}
Merci,
Marc
Old 10-26-2010, 11:11 PM   #8
You gota quit parking the 18 wheeler in the living room!
ejsharp is offline   Reply With Quote
Old 10-29-2010, 10:24 AM   #9
Thanks for all the tips! The oil tech just left. My burner was a MESS. The diagnosis was this - the fins in the flue in the water heater were caked with junk. He had to use a long serrated knife tool to clean it up. He also replaced the "eye" since it was heat damaged, and did a tune up with a nozzle, etc. He said that it was likely delayed firing and would blow smoke out into the room, which the furnace would pick up from ambient air and pump through the house.
Lesson learned, keep up the maintenance plan on the water heater!
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
Remove Burnt Smell From House sweaty General DIY Discussions 14 02-29-2012 01:20 PM
septic issue? musty smell in house, and toilet won't flush karen71 Plumbing 5 02-18-2010 04:14 PM
insulation smell in my house baby12121 Building & Construction 5 02-02-2010 09:45 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
