Dialing In A New Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 07:14 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
400 cfm per ton per cooling so 2 tons logically be on a lower speed. That's what we're saying?
Doc Holliday is offline   Reply With Quote
Old 10-17-2011, 07:15 PM   #17
An old Tradesmen
Rewards Points: 7,370
Originally Posted by Doc Holliday View Post
So the blower on heating mode is on high speed in that situation, is that correct? And the blower is on low for cool?
In that situation, yes.
Old 10-17-2011, 07:19 PM   #18
You do realize I've only worked in hvac in Houston, Texas, right? I'm lost when it comes to what I deem "abnormal" situations such as that.
Down here the cooling always trumps the heating and by far.
Old 10-17-2011, 07:20 PM   #19
An old Tradesmen
LOL... Texas may be big, but the country is much bigger yet, and more varied in applications then what anyone can see from one location.
Old 10-17-2011, 07:21 PM   #20
I remember the stories over there of guys working on units in sub zero weather, those guys taking pictures out in blizzards while working on units and posting them, and me thinking, "No way in hell would I ever do that."
I'd change careers if I moved up north.
Old 10-17-2011, 07:23 PM   #21
Oh, I know that now but before I got onto these hvac forums a few years back I was completely blind to that. I seriously thought it was all the same..
Old 10-17-2011, 07:26 PM   #22
An old Tradesmen
I work on A/Cs that run 365 days a year. And yes, sometimes I have to shovel snow to get to them.
And then there are the RTUs that I work on for heat when its sub zero outside and with a 20 mile an hour wind blowing yet.
Old 10-17-2011, 07:30 PM   #23
JJboy's Avatar
clean room A/C works 65F inside, doesn't matter the outside temp
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-17-2011, 07:35 PM   #24
JJboy's Avatar
Well..... US is bigger than Texas.....I'm surprised......
Old 10-17-2011, 08:22 PM   #25
Yep. Same with that 80,000 95% furnace and a 3 ton AC. Heat would need to move almost 1500 cfm for a 50 degree temp rise. The AC would be 1050-1305 cfm depending on the area's humidity. Then you'll get the occasional blower on high makes the static too high and a lower speed actually moves more air.
Old 10-17-2011, 08:24 PM   #26
I guess in my small world I never gave much thought to blizzards and snow up to your eyebrows up north. Outta sight and outta mind, I guess.
I'm more than good being in Texas, wouldn't want it any other way.
The Following User Says Thank You to Doc Holliday For This Useful Post:
JJboy (10-17-2011)
Old 10-17-2011, 08:30 PM   #27
Makes all too much sense, thanks for explaining. I'm just so used to the wonderful joys of cooling mode only. We have really no need for heating hardly once every ten years. Seriously, we use heating two or three weeks out of the year and even then it's not daily. At Christmas time I'm usually running around in shorts and a t-shirt, and eggnog. Lots and lots of eggnog.
Old 10-17-2011, 08:32 PM   #28
There is not enough money in the US of A to pay me to do that, period.
Old 10-18-2011, 03:40 AM   #29
An old Tradesmen
It bites, but you get use to it.
Old 10-18-2011, 03:04 PM   #30
You get used to it, or go broke, in my neck of the woods.
brandonmcginnis is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
