Old 08-13-2008, 12:46 PM   #1
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed
I just installed a Lenox a/c and heat pump unit in my house. Everything is ready to go except for wiring up the thermostat to the outside unit and the air handler. I have the Lenox, 13HPD outside unit, CD26UH-024-R Air Handler unit with the Heat Strips ECB26-10CB-P.
I have the manual for each of these. Unfortunately, the air handler manual shows how to wire the thermostat one way and the outside unit and heat strips show to wire it another way. Also I am not sure what emergency heat is. I have the heat strips but I am not sure if this is what they mean by emergency heat.
Please let me know which wiring diagram is correct for my application. Any info would be appreciated. Thanks.
The first picture is the wiring diagram from the air handler manual.
Pics 2 & 3 are from the outside units manual.
The last picture of a diagram is from the heat strips manual.
FYI: I have called Lenox 3 different times and received 3 different answers. First I was told I have emergency heat, then I was told I don't have emergency heat just auxillary electric heat strips.
twilightcall is offline   Reply With Quote
Old 08-13-2008, 12:49 PM   #2
Here are the other pics.
diagram-use-lenox-thermostat-wiring-setup-heat-pump-lenox-techs-needed-dsc04599.jpg   diagram-use-lenox-thermostat-wiring-setup-heat-pump-lenox-techs-needed-dsc04600.jpg   diagram-use-lenox-thermostat-wiring-setup-heat-pump-lenox-techs-needed-dsc04601.jpg
More On This Topic
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
If you just changed the spark plugs, the next step is testing the job. Everything should be alright if you replaced one wire at a time or took pictures and drew diagrams of the location of the wires from the distributor cap to the plug. Let's say you... Read More »
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
Luxaire heat pump wiring diagram StevieRay HVAC 5 07-02-2008 11:08 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
