Diagnostic Codes On Carrier WM 9200 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 03:18 PM   #1
Question
Diagnostic codes on Carrier WM 9200
I have a Carrier Weathermaker 9200 furnace that won't ignite. I already replaced the HSI thinking it had gone bad, but nothing changed.
I guess I have an older model as there is no display that shows the error codes, but rather a red LED that flashes. Problem is, I don't know how to interpret the flashes.
I get 3 quick flashes, followed by three additional slow flashes. Does this mean "33"?
Thanks for your help!
Scanner313 is offline   Reply With Quote
Old 11-07-2013, 03:31 PM   #2
OK, I figured out how to interpret the code, thanks to another post on this site.
So I have an error 33 code. Any suggestions on what I can do determine the cause?
NOTE: I have ZERO experience with furnaces, so if there is something that I shouldn't be messing with, please let me know. Thanks!
Old 11-07-2013, 04:23 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 386
33 is a limit or flame rollout switch is open. Both are serious and you should get a Pro to find out what happened/caused them to fail or trip. Resetting them if there is a dangerous condition is not a good thing to do. THat furnace is prone to cracked secondary heat exchangers and Carrier had a recall/class action lawsuit over them so you should get it checked by a Carrier tech as they are the only ones who can get the warranty 4 U.
Old 11-08-2013, 08:42 AM   #4
Thanks for the info Yuri. Since there was a recall, did Carrier extend the warranty or re-warranty the system? Mine is at least 8 years old.
Old 11-08-2013, 08:46 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 386
the heat exchanger has a 20 yr or lifetime warranty and they pay a set $$ amount to the dealer for labor to change it. after that you are back to normal and on your own.
Old 11-08-2013, 08:57 AM   #6
Awesome! Thanks again Yuri!
Old 11-08-2013, 09:03 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 386
Yur welcome. if he is there to just fix the furnace get him to check the heat exchanger and that requires removing the fan and crawling it to look at the bottom for water stains. some guys may not want to do that but ask his dispatcher or service manager to send a guy who will.
Carrier 9200 furnace problem, help! DariusRBKS HVAC 19 03-13-2013 05:24 PM
Carrier 9200 problem mikema HVAC 13 08-10-2012 07:32 PM
Carrier Weathermaker 9200 Codes 34/14 have ignition Hawxter HVAC 9 12-31-2011 03:02 PM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 06:18 AM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 12:44 PM
