Old 12-21-2012, 02:50 PM   #1
I have gas!
Clutchcargo's Avatar
Diagnosing Adams Speedflame igniter
I've got an Adams speedflame that won't ignite. It's got a spark igniter but it does not spark. I tried to check voltage across the terminal where the igniter is plugged into but it only reads a few volts (most likely phantom power). Any ideas on what I can check?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-22-2012, 10:34 AM   #2
I have gas!
I guess no one seems to know.
From what I've been reading, ignition modules are fairly generic. it controls the spark and the gas valve.
Here's my plan.
I'm going to check the input voltage at the ignition module. If it has voltage, I'm going to assume that the ignition module is at fault and swap it out.
If it doesn't have voltage, I'm going to go upstream to the transformer and do the same.
Old 12-22-2012, 04:52 PM   #3
I have gas!
After some more digging, I'm becoming more certain that the ignition module is kaput.
It does have voltage running to it and the gas valves appear to operate correctly but no spark and no voltage from the terminal to make it spark.
I have not pulled it out yet because it's buried behind a fan and the wires are very tight in there so to slide it out will require some time.
Anyone familiar with the EPI-200 ignition module? Are these interchangeable or do I need to replace with an exact model? And finally is there something obvious that I should check first?
TIA
Old 12-22-2012, 07:32 PM   #4
An old Tradesmen
Not familiar with that module.
If your getting 24 volts to the gas valve but not spark. if the wire isn't grounded out, its usually the module.
Hot surface igniter and gas valve not always working during call for heat Modify_inc HVAC 12 12-10-2012 06:46 PM
Igniter Silicon Nitride testing JJboy HVAC 2 10-28-2012 10:52 PM
Comfortmaker RPJ2 igniter and transformer output Keith1394 HVAC 0 01-18-2012 10:11 PM
Rheem No 120VAC Igniter Help Benihana HVAC 5 01-04-2010 04:39 AM
Goodman 80%, igniter glows no flame diyjohn HVAC 16 11-20-2008 03:47 PM
