Determining Tonage - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2007, 09:06 PM   #1
Rze
Average Joe
Rewards Points: 79
Determining Tonage
What is the formula for determining what size AC unit is needed? I know that there are many different factors, however I am just looking for a high level rule of thumb calculation. The home is a raised ranch in NJ, approximately 1750 Sq FT
Thanks!
Dave
Rze is offline   Reply With Quote
Old 10-17-2007, 10:39 AM   #2
sq footage divided by 400 usually gets you close. In your case, you would probably need a 4 or 4.5 ton unit.
cjett is offline   Reply With Quote
Old 10-17-2007, 04:21 PM   #3
scotch on the rocks
hvactech's Avatar
first, you must take into consideration the size of your furnace and ductwork, for every ton of refrigeration 400 CFM of air flow are needed, if the fan or the duct cant handle the CFM then you are going to have all sorts of problems with the new A/C, check the ductwork and furnace and dont go crazy over the top, bigger is not better, for a house like your I'd go with a 2.5 tons unit if the fan/duct allows for it.
hvactech is offline   Reply With Quote
Help determining header size Griffith.N Building & Construction 15 10-03-2007 04:40 PM
Determining drain pipe routing? tigerbalm2424 Plumbing 3 03-09-2007 08:12 AM
Determining if I have enough room cibula11 Electrical 24 02-04-2007 10:48 AM
Determining SQ Ft of my home??? Sellncars Building & Construction 2 09-03-2006 11:33 AM
