Depth To Install Wall Casing For Wall Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 03:05 PM   #1
Depth to install wall casing for wall unit?
So I got this LG wall case and the instructions are pathetic. Can I line the front lip of the case flush with the wall or does need to protrude a few inches or what not? What's up LG with the non existant instruction?
Freakaloin is offline   Reply With Quote
Old 01-19-2013, 03:56 PM   #2
Rewards Points: 1,216
Go on line or call LG Tech service and explain your situation they will give you the proper information.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
Cooling a whole house on a wall AC unit RedHelix HVAC 15 07-20-2011 11:53 AM
Insulating draft from in wall heating and cooling unit jor1228 HVAC 1 12-25-2010 10:32 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
