Delta T - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 09:20 PM   #1
Delta T
What should be the typical temperature difference between the intake and "exhaust" of a split system AC? How much does it depend on the intake temperature? I'm guessing that if the inlet is 40F vs 80F, delta T will be lower.
peterk is offline   Reply With Quote
Old 04-14-2009, 09:34 PM   #2
An old Tradesmen
Rewards Points: 6,480
Are you talking heating or cooling.
Old 04-15-2009, 07:49 AM   #3
biggles's Avatar
18F split return/supply on the air handler,and 10F on the condenser in/and blowing up and out if the charge is right.
Old 04-15-2009, 07:52 AM   #4
The proper terms are return (intake) and supply (exhaust) across which you measure delta T. And as been has suggested the numbers are different whether in heating or cooling mode.
dac122 is offline   Reply With Quote
Old 04-16-2009, 08:37 PM   #5
I'm talking about cooling.
I recently bought my first home and the HVAC system is very very old. With a 65F return the delta T is only 9 degrees. I'm trying to decide weather to get it serviced and make it last however long it will last, or bite the bullet and get a sweet 16 SEER system and that fat government rebate.
Old 04-17-2009, 07:21 AM   #6
An old Tradesmen
9 is not much.
So it has a problem of some sort.
Weather its a diry coil, or low on charge or some other problem, can't say.
Depending on your location. You may be better off getting a new system. And upgrading to a heat pump.
The price difference is covered by the rebate. Plus you save some money on your heating bill every year then also.
New Delta faucet drips Ultrarunner2017 Plumbing 10 02-28-2012 10:34 AM
Glacier Bay, Peerless, Delta Yoyizit Plumbing 2 03-11-2009 12:20 PM
concrete basement - installing laminate on delta SDG Flooring 1 12-29-2008 09:10 PM
wiring a 220 volt delta unisaw and delta x5 planer naveall Electrical 13 10-30-2008 02:30 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
