Delay Indoor Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 02:48 PM   #1
UncaYimmy's Avatar
Delay Indoor Blower
My heat pump manual can be found here (Goodman PHK060-1) :
http://www.dnmech.com/lit/QRP-08.pdf
Just recently there has been a delay between the fan outside and the indoor blower. It seems to vary from five or six minutes (when it hasn't run for a while) to virtually no delay if I manually change the thermostat to cut on shortly after the unit has stopped. It's blowing heat just fine.
This doesn't seem right to me, but we recently just switched over to heat. I replaced the thermostat this summer, and I didn't notice any such delay on AC.
Suggestions for the next step?
Thanks in advance for any and all assistance.
UncaYimmy is offline   Reply With Quote
Old 12-23-2010, 12:19 AM   #2
UncaYimmy's Avatar
Bueller?
Bueller?
Old 12-23-2010, 06:02 AM   #3
An old Tradesmen
Rewards Points: 6,132
A BIG hammer.
Which one is delaying. The outdoor fan, or the indoor blower?
Old 12-23-2010, 11:12 AM   #4
UncaYimmy's Avatar
The indoor blower. The outside fan cuts on. The indoor blower can delay anywhere from less than a second to five minutes.
Old 12-23-2010, 07:39 PM   #5
An old Tradesmen
probably a bad sequencer.
Old 12-24-2010, 05:10 PM   #6
UncaYimmy's Avatar
Do you think that's something a layman such as myself should attempt to replace? Consider me reasonably skilled and very cautious around electricity.
Thanks!
Old 12-24-2010, 06:04 PM   #7
An old Tradesmen
You have to know your own limitations. Some people can, some can't.
Old 01-04-2011, 04:15 PM   #8
UncaYimmy's Avatar
Here's a link to the parts for this model. I'm thinking this part is defective and should be replaced. I'd appreciate some advice as to whether this is the right decision or not.
Thanks!
Old 01-04-2011, 04:19 PM   #9
An old Tradesmen
Thats probably the part you need.
Old 01-10-2011, 04:39 PM   #10
UncaYimmy's Avatar
I replaced that part, but the problem persists. Any other ideas?
Old 01-10-2011, 07:00 PM   #11
An old Tradesmen
Still delaying as much. or is it more like 30 seconds now?
Old 01-12-2011, 09:27 PM   #12
UncaYimmy's Avatar
The first time after I replaced it, it took about a minute. Since then it was going about 25 seconds or less. Today was warmer, so it didn't run all day. This evening, when it fired up for the first time, it took about 5 minutes.
Is there a capacitor that needs to charge up or something?
Old 01-12-2011, 09:44 PM   #13
An old Tradesmen
No, the capacitor for the motor wouldn't change the way the motor starts after changing the sequencer.
Check to make sure it is getting 24 volts, and not only 18 or 20 volts.
Old 01-12-2011, 10:38 PM   #14
UncaYimmy's Avatar
That I'm not sure how to do. Any tips on what to tap?
Old 01-13-2011, 04:53 AM   #15
An old Tradesmen
The 24 volt terminals of the sequencer. They are the ones at the base of teh sequencer, were teh sequencer mounts to the air handler housing.
Tags
delay , goodman phk060-1 , indoor blower
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Gas ignition delay in my boiler... spup345 Plumbing 0 11-29-2010 01:23 PM
On/off fan delay settings? ls3c6 HVAC 9 11-04-2009 11:04 AM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 06:17 AM
2 Stage AC with older Furnace? SteveTheBuilder HVAC 5 07-18-2008 09:04 PM
