Dehumidifier For Very Wet Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 08:11 PM   #1
Dehumidifier for Very Wet Basement
I am looking for a super-duper dehumidifier to dry down a very wet basement/cellar. The best that I can find online is 70-pints. Does anyone have a recommendation for something stronger that won't require new mortgage, perhaps $200-$400? It needs to drain into sump pit. Also, it would help if it were Energy Star to avoid blowing breaker and shutting off sump pump. I know, I know, I need to do some breaker box updating. Please help with advice. Thank you.
SRhoda is offline   Reply With Quote
Old 10-13-2009, 08:19 PM   #2
A dehumidifier is like running a good sized AC
If your basement is wet it may run non-stop
Its better to fix the problem then use a band-aid
Have you already tried a 70 pt model?
I actually have (2) in my basement, one was $75 off craigslist
Old 10-13-2009, 08:57 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I found that a dehumidifier + industrial fan works well. The dehumidifier only remotes humidity from air that passes through it, so if you get a large fan to move the air around it will help.
I have one in my basement I run all the time, mostly to help deter spiders (spiders like it damp, and don't like it dry). If your basement is actually wet, and not just humid, I would fix that problem, but in the meantime you can still use the dehumidifier.
I've been wanting to mod mine so I can attach a hose to it and let it drain. I have to empty it every 2 days or so. When I first put it it would run for no more then 4 hours but now I got rid of most of the humidity. It was just a build up. Now it's fairly nice and dry. On the low setting it actually gets nothing.
This is the one I have:
http://answers.canadiantire.ca/answe.../questions.htm
It's actually incredible the water you can pull out of the air with these.
Tags
basement humidity , dehumidifier , wet basement
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 04:29 PM
Dehumidifier install in basement? gone_fishing Remodeling 3 03-09-2008 07:25 PM
