Dehumidifier Mode On A/C System - HVAC - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 10:02 AM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,192
Dehumidifier Mode on A/C System
I have a new two stage furnace and a new A/C system.
I was reading a thread about a guy that had the wrong thermostat installed on his furnace and it wouldn't run in "dehumidifier mode". Is this the correct way to say this?
The whole system is oversized at present as I will be doing a second story addition soon. I'd like to get a better thermostat and hopefully the system can run slower to draw out more humidity.
Is this correct?
The thermostat installed on my unit has only AC/Heat, fan ON/OFF.
My furnace is a Luxaire model TM9V080C16MP11.
I believe it's a two stage with DC motor.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 08-18-2013, 11:22 AM   #2
An old Tradesmen
Rewards Points: 7,372
A thermostat like the Honeywell IAQ(YTH9421) can slow your blower down, and provide control of both stages of heat that your furnace has. Along with both stages of cooling if your A/C is 2 stage.
Is the A/C 2 stage. And what size is it.
The Following User Says Thank You to beenthere For This Useful Post:
123pugsy (08-20-2013)
Old 08-18-2013, 05:26 PM   #3
123pugsy's Avatar
Thanks.
House at present is 1144 sq feet with 8' high 2x4 walls bungalow.
Future house will be 2288 sq feet with 2x6 walls.
A/C is Luxaire, 3 tons, TCGF36S41S1.
All thermostat wiring diagrams refer to Single Stage. So, I guess I'm toast then?
File Type: pdf LUXAIRE TCGF36S41S1 AIR CONDITIONER 1.pdf (99.1 KB, 91 views)
Old 08-18-2013, 07:39 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
The IAQ stat BT suggested will do what you want if wired properly. I would recommend the upgrade though to the new VP 8000 stat (TH8321R1001) and EIM (THM5421R1021). This setup would allow for wireless outdoor sensor and indoor sensors and internet gateway (for internet/smart phone access) all to be added as wanted/needed.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-20-2013, 04:34 AM   #5
123pugsy's Avatar
Thanks hvactech.
I will do some research to see which way I will go with this.
So with the single stage AC, is there any chance of the coil icing up when the thermostat calls for Dehumidify/low speed fan?
Old 08-20-2013, 05:42 AM   #6
AKA HVACTECHFW
Not typically, no... but that all depends upon your duct system. It typically doesn't slow it down enough to ice the coil but only enough to make the coil colder than normal and cause extra dehumidification.
IT IS WHAT IT IS
Old 08-20-2013, 11:47 AM   #7
123pugsy's Avatar
Thanks.
How important is it to have the thermostat with the outdoor sensors?
Do they come into play when the thermostat is calling for Dehumid?
Oh, and the scariest thing is; can the wife get on her iPhone and start changing the settings?
Old 08-20-2013, 05:05 PM   #8
AKA HVACTECHFW
Dehumidification with ac does not use outdoor temp in consideration with controlling humidity.
Dehumidification set point can be changed using a smartphone depending upon which control you choose if it has WiFi access.
IT IS WHAT IT IS
Old 08-20-2013, 07:13 PM   #9
123pugsy's Avatar
Thanks.
For me, I can't see needing the WiFi option so I may go with the IAQ mentioned earlier.
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
heat pump freezing problem av-geek HVAC 8 02-02-2012 07:16 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 02:53 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
