Defrost Tempering For Lennox XP21/SLP98/iComfort - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 01:12 PM   #1
Rewards Points: 18
Defrost tempering for Lennox XP21/SLP98/iComfort
I have the Lennox XP21/SLP98/iComfort system. Per the manual, the iComfort does not have defrost tempering function, so cold air blows out during defrost. What I've noticed is that the "W" terminal from the XP21 still produces 24VAC during defrost. Will it be possible to reconnect this back to the "W1" (via defrost tempering kit 67M41) in the SLP98 so it triggers the furnace during defrost? Will it mess up the iComfort or the system? This was how it was previously hooked up when I had the Honeywell IAQ thermostat. I later changed to the iComfort as it gave me better control over the system. Thanks.
klingon is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 07:07 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
