Defrost Mode On Heat Pump. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 03:15 PM   #16
Why is your heat pump running for 90 minutes straight, at 50 degree ambient temperatures?
Master of Cold is offline   Reply With Quote
Old 10-23-2011, 03:20 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
its not 90 min straight, its accumulated 90 min of total run time.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-23-2011, 03:21 PM   #18
AKA HVACTECHFW
Originally Posted by roku View Post
"From W2 of defrost control to switch" Is this wired to the top of switch?
"From switch to heat element terminal in air handler" Is this wired to the bottom of switch?
Would the wire from the defrost control board be considered the power source?
W2 from defrost control is what turns on the aux heat during a defrost call. All you need to do is find that wire, cut it and put one side to the top and the other side to the bottom. You are making it seem more difficult than it is.
IT IS WHAT IT IS
Old 10-23-2011, 03:37 PM   #19
That's is going to depend on the unit
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Hot Water Recovery- Heat Pump A/C mode AndrewF HVAC 1 03-05-2009 06:04 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
