Defrost Mode On Heat Pump. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 12:20 PM   #1
Defrost mode on heat pump.
My heat pump is set to defrost cycle at 90 minute intervals. I recently noticed that the defrost came on when the temperature was 59. This does not seem right at that temperature. At what temperature should the system be in for a call for defrost mode. What would cause this?
roku is offline   Reply With Quote
Old 10-23-2011, 12:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
do to your control being a timed defrost control board it will defrost at 90 min run time no matter what the outdoor temp is.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-23-2011, 12:38 PM   #3
If this is the case. I'd like to manually control when the auxiliary heat strips come on in defrost mode. It seems ridiculous to have them come at say 50 or even 40. I know I can disconnect the wire that engages the heat strips while in defrost mode. Is there a switch I can use so I would not have to physically disconnect said wire?
Old 10-23-2011, 12:54 PM   #4
AKA HVACTECHFW
yes, a switch could be used at the air handler that would break the circuit for the strips from the heat pump, but while the unit is in defrost it will be putting cold air in the home then.
IT IS WHAT IT IS
Old 10-23-2011, 01:05 PM   #5
I fully understand that. But I am thinking more on cost savings at those temps as compared to dealing with cool air during the defrost mode. I can tinker with it to see what temp I can withstand without the auxiliary heat strips coming on. What type of switch can I use to make this happen?
Old 10-23-2011, 01:17 PM   #6
AKA HVACTECHFW
honestly just about any switch will work. spst.... a light switch would work or something from a auto parts store would work as well. It's not going to pull more than 1 amp through the switch. All you are doing is opening and closing a circuit.
IT IS WHAT IT IS
Old 10-23-2011, 01:23 PM   #7
Would I not need a switch specific for that of a thermostat wire? Not sure but I think it is 24vac for the wire.
Old 10-23-2011, 01:24 PM   #8
AKA HVACTECHFW
yes, 24vac.... so anything rated for that or higher voltage will work
IT IS WHAT IT IS
Old 10-23-2011, 01:28 PM   #9
Do they sell a 24vac switch in auto parts stores? Having trouble finding one online.
Old 10-23-2011, 01:38 PM   #10
AKA HVACTECHFW
not specifically for 24VAC... if you are not sure then go to the hardware store and buy a 2 X 4 metal box, light switch, and cover.
IT IS WHAT IT IS
Old 10-23-2011, 01:52 PM   #11
There should be a defrost sensor on your heat pump that starts the timer when the line temp is 28-30 degrees. When the line temp stays above that then the timer is not activated but the board will initiate a defrost after 6 hours of run time no matter what the temp for oil return to the compressor. Low on charge, dirty coils,a weak capacitor or a dragging motor can all cause frost to form too soon resulting in excessive defrost cycles. If there wasn't frost then it could have just been the oil return cycle time.
Old 10-23-2011, 01:58 PM   #12
AKA HVACTECHFW
they do not all have that sensor
IT IS WHAT IT IS
Old 10-23-2011, 02:01 PM   #13
So are you saying that I can use a basic single pole switch for this? If so, is this how to wire it? Wire from airhandler hooked to top of switch and wire to heat pump condenser hooked up at the bottom of switch.
Old 10-23-2011, 02:15 PM   #14
AKA HVACTECHFW
yes, basic single pole switch. From W2 of defrost control to switch. From switch to heat element terminal in air handler.
IT IS WHAT IT IS
Old 10-23-2011, 03:05 PM   #15
"From W2 of defrost control to switch" Is this wired to the top of switch?
"From switch to heat element terminal in air handler" Is this wired to the bottom of switch?
Would the wire from the defrost control board be considered the power source?
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Hot Water Recovery- Heat Pump A/C mode AndrewF HVAC 1 03-05-2009 06:04 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
