Old 03-27-2009, 02:03 PM   #1
Defrost in 40+ temps
Is there any reason a HP would go into defrost mode in temps warmer than 40?
It has not been colder than 39 for the past few days.
It defrosted at 12:30AM (Outside Temp: 43F, Suction: 102F, Condenser Temp: 32)
3:45AM (Outside Temp: 41F, Condenser: 38F)
6:05AM (Outside Temp: 40F, Condenser: 33F)
9AM (Out: 41, Condenser: 31F )
so far today for a total of 6 minutes.
Would it go into defrost mode if there was a charge issue?
I thought most units didn't go into defrost until the condenser was below 28 and the built in timer accumulated enough time at that temp. (mine is set to 90 minutes)
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 03-27-2009, 02:16 PM   #2
An old Tradesmen
Yes, it would.
Along with a defrost control or sensor issue.
A restricted outdoor metering device.
A dirty outdoor coil.
A restricted liuid line filter drier.
Old 03-27-2009, 03:10 PM   #3
Thanks. I'll have a guy come out and check it then now that it is warmer out and they can do a better diagnostic of the system.
-Andrew
DIY hobbiest
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
geothermal air coil temps rodmasson HVAC 7 02-17-2009 02:32 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
