Default Settings Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 03:57 PM   #1
Hello,
I had a HVAC guy come out to my house because my thermostat just displayed "Wait" on the panel and my AC would not kick on. He replaced a bad capacitor, and tested the unit and the AC immediately turned on. Before I called him, I played around with the settings on my thermostat and now the only way I can get my AC to turn on, is to go into the test settings and test the AC fan. That will turn the AC on and cool the house down. Besides that, it still displays the "wait" command on the thermostat. I am assuming there is a default setting that I messed up, but have no idea how to change it or what to change. I have a Trane XL1600 heat pump with a Honeywell TH8321U1006 thermostat. Any help or advice is greatly appreciated!!!
SCotty
fidkid83 is offline   Reply With Quote
Old 05-21-2013, 08:12 PM   #2
An old Tradesmen
Rewards Points: 6,580
You can download the install manual with all the setting info from here. http://www.alpinehomeair.com/viewpro...ions_brochures
Old 05-21-2013, 09:06 PM   #3
Beenthere...thanks for the link. I have gone through the settings and to the best of my knowledge have it set correctly. That being said, the thermostat still only displays "wait". Is there something I'm missing, or could my thermostat be bad?
Old 05-21-2013, 09:38 PM   #4
An old Tradesmen
Could be bad. They have a 5 year warranty on them.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (05-22-2013)
Electrical Newbie - Voltage Tester has "O" "L" "H" Settings - Not sure if wire is hot splendorlex Electrical 15 11-22-2014 07:59 AM
Hydronic Radiant Floor Boiler settings lithiumus HVAC 1 10-10-2012 04:48 PM
Thermostat settings for a heatpump Jimbo65 HVAC 6 12-13-2011 10:31 PM
Honeywell L8124L Settings on Oil Boiler shawnmd HVAC 1 10-24-2010 08:11 PM
Aux and Emergency CPH settings indvid HVAC 2 03-02-2009 04:31 PM
