Decent Free Heat Loss Calculator - HVAC - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 12:42 PM   #1
raylo32's Avatar
Rewards Points: 1,252
Decent free heat loss calculator
This is a pretty nice tool. Not as detailed as the Manual J calc... for instance it does not let you specify which direction windows are facing. But for me it was just fine since I have about equal glass facing north and south. I think it captures the envelope of a structure pretty well. And the price is right. As usual, your mileage, and BTUH, may vary.
Oh, it isn't obvious from the input form but the calculator assumes an interior temp of 70 degrees F.
http://www.builditsolar.com/Referenc...s/HeatLoss.htm
raylo32 is offline   Reply With Quote
Old 08-27-2011, 07:49 PM   #2
An old Tradesmen
Rewards Points: 6,860
Did it let you do room by room.
Old 08-27-2011, 11:00 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Not decent. Guesstimation without window info.
Doc Holliday is offline   Reply With Quote
Old 11-17-2014, 05:13 PM   #4
The_Pinner's Avatar
Rewards Points: 78
Do you have any better ones, Doc?
The_Pinner is offline   Reply With Quote
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
heat loss through hollow cinder blocks diy4life Building & Construction 11 11-19-2009 10:37 AM
Recessed/Can Lighting Heat Loss? TomServo HVAC 55 11-14-2009 08:23 PM
Heat Loss Related Question mynd66 HVAC 14 10-25-2009 02:42 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
