Old 12-24-2011, 11:26 AM   #1
Dearborn heater
Hi. I am new here and would like to say hi to everyone.
My question is I have an old Dearborn heater. Model DKS-65-LP. I would like to know where to get a parts manual. It seems like that type of stuff is top secret. I have contacted websites online and info was very little.
Is there anyone that can help or that can hook me up with a electronic copy.
joebudd is offline   Reply With Quote
Old 12-24-2011, 12:40 PM   #2
Dearborn heater
http://www.dearbornheater.com/
http://www.dearbornheater.com/PARTS.htm
harleyrider is offline   Reply With Quote
Old 12-24-2011, 01:30 PM   #3
biggles's Avatar
Dearborn heater
try here for prices has to be brand name items within http://www.bestbuyheatingandairconditioning.com/
Old 12-24-2011, 01:45 PM   #4
Dearborn heater
I sent an email to the Dearborn site and got very little info. Actually no info.
Old 12-26-2011, 03:18 PM   #5
Dearborn heater
Can this be cross referenced. Alpha tafco TF-5?
Old 12-31-2011, 04:14 PM   #6
Dearborn heater
Ok forget the paper work. I had the burner out on the bench and unable to keep it burning. Took the valve apart and there was corrosion in it. I don't think there coil/solenoid works correctly either. So now I need a new valve. Now if someone can steer me in the corect direction. I will tell you what I need. Valve needs to have 1/2 in 1/2 out at 90 degrees, 24vac 1/2psi, needs a pilot, thermocouple, A knob with off/on/LO. Needs to be LP and at least 65000 BTU's. Can someone help come up with a part number so I can look at the specs. Thanks
Old 01-03-2012, 05:07 PM   #7
Dearborn heater
Ok minor problem. The valve I have states (set 10"). The valve I am looking at buying because it looks the same states
(set 3.5"). Is mine LP and the other natural gas? Now can I convert it easily? Thanks
Old 01-14-2012, 03:40 PM   #8
Dearborn heater
OK Heres the deal. I bought the essex natural gas valve. Looks like the one I have. The new valve has in and out on opposite sides the old valve was 90 degrees. Not a big deal, put a 90 in and had to reduced it to 3/8. Took the old spring and put it in the new valve, and made a manometer. Put the burner unit on the bench rigged up the gas and fired it off. Unit was very close to 10" w/c. Adjusted it and shut it down. Put the burner in the heater housing and pipe the gas. I used 1/2 black iron. I put my union and my trap and gas valve in, hook up the gas. I lite the pilot, turned up the thermostat and waited. 30 seconds later the burner lights. A couple of minutes later the fan kicks in. Not too bad for never doing this before. My advice, always read about what you are planning on doing. Ask questions, and read some more.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Min distance from baseboard hotwater heater capslock General Discussion 2 05-25-2010 08:31 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
