Dead Mice In Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 02:10 PM   #1
dead mice in furnace
Our washer pipe broke in our home, flooded and cause considerable damage. The work to correct included cleaning of our duct work. The crew that cleaned our ductwork found 20+ dead mice carcasses in various stages of decay. Some had been electrocuted, some had simply died - yuck! One unfortunate mouse had died in the filter folds. We do smell dead mice every fall. I do not think we have mice residing in our newer (<10 years old) home and I have never seen any sign of them. I have spoken with our local HVAC specialist and they were not able to tell me how the mice are landing in the furnace. There is a 3 inch PVC vent outside (steam flows out when the furnace is running) that has no screen. The HVAC people said not to screen this pipe because it could freeze shut. This makes sense in our cold climate because it drips steam when the furnace is running. Could the mice be entering from this pipe? My spouse and I are arguing about this. He says it is not possible for mice to get to the furnace through this pipe. He says that the mice are residing in the house and then go into the furnace through our ductwork. Any ideas?
TerPer is offline   Reply With Quote
Old 01-13-2011, 02:27 PM   #2
Rewards Points: 558
You can put a wire mesh over that pipe and have no problem of freezing. At least one avenue for the mice would be closed and then you can work on the other areas on where they might be going in from.
epson is offline   Reply With Quote
Old 01-13-2011, 02:28 PM   #3
Stay-at-home GC
In many homes with central air, the return air system is often ductless (especially in production style homes). If not carefully detailed during construction to seal correctly it essentially becomes part of the floor joist system. Since a mouse can squeeze through a hole the size of a pencil, its a very nice warm way to spend the winter .
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-13-2011, 02:33 PM   #4
mice can get in thru opening so small it seems impossible for them to get in.
Sounds like a family of only one mom and dad. Other wise I think you would have more carcasses.
If there are more then I would put out traps along the walls (that'the way mice travel. Seldom see them cross an open space.
Keep putting out traps until you don't gt any more.
Good places are under sinks close to food sources..cabinets...frige..
good luck.
PS
Don't let nobody tell you it's bad house keeping. There are million dollar mansions that have rats in them.
hvaclover is offline   Reply With Quote
Old 01-13-2011, 02:47 PM   #5
Stay-at-home GC
A Builder I was associated with finished 18 townhome units with no sheathing under the brick ledge cantilever. Even after we pointed the problem out to him, he proceeded to brick-to-grade. Mouse City!
Old 01-13-2011, 03:10 PM   #6
Geeze...
i am sure our fellow tradesman in the home building side are not happy to read about such things. I would be angry if I heard an HVAC tech did something similar just to save a few pennies.
Old 01-13-2011, 03:57 PM   #7
Rewards Points: 558
You would be surprised what goes on a job site…
Old 01-13-2011, 04:01 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 116
They cannot get thru that intake or exhaust pipe into the main ductwork as they are seperated by the furnace heat exchanger. If you have a fresh air pipe from the outside to the return duct to bring in fresh air then that is an open conduit for them. A mouse can get thru a 1/2" hole and I am sure there are no shortage of them in some houses. Call Billy the Exterminator.
Old 01-16-2011, 07:26 PM   #9
Possible fix
Try using moth balls. Put them by your exhaust pipe, and any other entryways that the mice may be taking into the house. This is usually a good deterrent for any invaders.
Handymench is offline   Reply With Quote
How to Get Rid of Mice biz123 Pest Control 8 08-06-2012 07:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
