DDistributing Heat From A Fireplace Insert. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 05:12 PM   #1
dDistributing heat from a fireplace insert.
I primarily heat the house with a fireplace insert at one end of the house. Our bedroom and bath at the other end of the house stays very cold. I would like to distribute some of the excess heat with a fan and ductwork to the bedroom and bath. I would need approximately 40 feet of ductwork and a fan. The area to heat is 350 square feet. House is well insulated.
What size and type of ductwork would work? What type of fan would be best? Can I go ceiling to ceiling?
hoosick falls is offline   Reply With Quote
Old 11-13-2010, 06:33 PM   #2
An old Tradesmen
Rewards Points: 6,142
If you put the duct work in the attic. You'll want at least an R8 insulation value.
Depending how warm/hot the area with the fireplace is. You will need a fan that moves 400 CFM or so.
Old 11-13-2010, 06:49 PM   #3
Smile
ductwork size
What size ductwork should I use? 4", 6", 8"?
Would I use an inline type fan? Does it go at the beginning, middle or end of the run?
Thanks for any assistance.
Old 11-13-2010, 08:00 PM   #4
An old Tradesmen
10" might need 12" depending how straight the run is or isn't.
Fan can go at teh beginning of the run or end, or middle. Where ever is more convenient for you.
Old 11-13-2010, 08:14 PM   #5
Thumbs up
Beenthere, thanks for your assistance. You were a great help.
Old 11-13-2010, 08:21 PM   #6
An old Tradesmen
Your welcome.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat n Glo fireplace wanna be handy General DIY Discussions 0 11-24-2009 01:39 PM
Removing a pre-fab fireplace insert MarkinTN1 Remodeling 1 10-10-2009 12:20 AM
Monessen Gas Fireplace Insert fisherro HVAC 3 12-25-2008 06:37 PM
