Dc90 Burner Doesnt Ignite-sometimes - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 07:27 PM   #1
Dc90 burner doesnt ignite-sometimes
Have a dc90 that at times burner does not ignite. Replaced igniter already,when I removed to clean one of the elements broke. Furnace seems to work okay when above 50 but below burner ignition comes on and other times not at all. Last week it never worked at all and Saturday outside temps went to 60 and furnace worked all weekend until tonight. Any help appreciated. I have read all posts here last week to try to fix this issue and one thing I have seen this is a great forum.
hded is offline   Reply With Quote
Old 12-17-2012, 08:28 PM   #2
An old Tradesmen
Rewards Points: 7,332
Check drain lines and trap.
Old 12-17-2012, 08:36 PM   #3
Roofmaster
Rewards Points: 2,210
Can you elaborate on DC-90 for those of us that dont have all the models down? Carrier?
Old 12-17-2012, 09:07 PM   #4
It is a Tempstar,I believe made by Heil. Forgot to mention igniter works okay and has a good pilot light when furnace starts up but burners will not light.
Old 12-17-2012, 09:14 PM   #5
Roofmaster
Have you cleaned the trap out and checked the pressure switch?
Old 12-18-2012, 05:43 AM   #6
Will do tonight. Drain line runs into garage and is pvc. Will be easy to cut and re-splice. Will let you know. Thanks in advance. Another thing I found is when burner does not come on you can shut furnace down for 15 minutes or so and when restarting burner will come on.
Old 12-18-2012, 08:01 AM   #7
Roofmaster
I found this very extensive post on this furnace. I seem to remember Yuri saying that the flame hood on these warps, and that might be your problem. Maybe he will chime in and help you, I am too green. But here is the link:
http://www.doityourself.com/forum/ga...ails-heat.html
Old 12-18-2012, 03:43 PM   #8
Thanks,this will be of help also.
pilot lit, burner won't ignite unless I blow on pilot light rl5 HVAC 7 01-06-2011 09:08 PM
gas hot water burner wont ignite on its own yoopgirl HVAC 1 12-12-2010 07:18 PM
Trane XE78 One Burner wont ignite ruckamuck HVAC 3 10-29-2010 10:08 PM
Gas Hot water heater, burner will not ignite hammerdome Plumbing 8 10-14-2009 05:04 PM
Utica Boiler Burner Won't Ignite jackjr1948 HVAC 8 03-02-2008 08:14 PM
