-   -   Dc90 burner doesnt ignite-sometimes (http://www.diychatroom.com/f17/dc90-burner-doesnt-ignite-sometimes-166734/)
hded 12-17-2012 07:27 PM
Have a dc90 that at times burner does not ignite. Replaced igniter already,when I removed to clean one of the elements broke. Furnace seems to work okay when above 50 but below burner ignition comes on and other times not at all. Last week it never worked at all and Saturday outside temps went to 60 and furnace worked all weekend until tonight. Any help appreciated. I have read all posts here last week to try to fix this issue and one thing I have seen this is a great forum.
beenthere 12-17-2012 08:28 PM
Check drain lines and trap.
jagans 12-17-2012 08:36 PM
Can you elaborate on DC-90 for those of us that dont have all the models down? Carrier?
hded 12-17-2012 09:07 PM
It is a Tempstar,I believe made by Heil. Forgot to mention igniter works okay and has a good pilot light when furnace starts up but burners will not light.
jagans 12-17-2012 09:14 PM
Have you cleaned the trap out and checked the pressure switch?
hded 12-18-2012 05:43 AM
Will do tonight. Drain line runs into garage and is pvc. Will be easy to cut and re-splice. Will let you know. Thanks in advance. Another thing I found is when burner does not come on you can shut furnace down for 15 minutes or so and when restarting burner will come on.
jagans 12-18-2012 08:01 AM
I found this very extensive post on this furnace. I seem to remember Yuri saying that the flame hood on these warps, and that might be your problem. Maybe he will chime in and help you, I am too green. But here is the link:
http://www.doityourself.com/forum/ga...ails-heat.html
hded 12-18-2012 03:43 PM
Thanks,this will be of help also.
