DC Motor For Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 09:26 PM   #1
Newly Retired
tuchodi's Avatar
DC Motor for Furnace
I am planing on changing my AC fan motor in my furnace over to a DC motor. Has anyone done this and if so what voltage did you go to and has it been successful? I am doing this to use my furnace fan to continually run to circulate heat from a wood stove.
tuchodi is offline   Reply With Quote
Old 08-06-2010, 10:15 PM   #2
An old Tradesmen
Rewards Points: 7,808
Are you trying to use a regular DC motor instead of a ECM motor?
Old 08-07-2010, 08:14 AM   #3
Newly Retired
tuchodi's Avatar
No it will be a ECPM or a ECM.
Old 08-07-2010, 08:26 AM   #4
An old Tradesmen
There are retrofit motors that you can get and use from Genteq.
The Following User Says Thank You to beenthere For This Useful Post:
tuchodi (08-07-2010)
Old 08-12-2010, 10:17 AM   #5
Newly Retired
tuchodi's Avatar
I just had an e-mail back from Genteq and they only supply ECM motors to OEM's and do not sell any retrofit ones. That is at least in Canada. Does anyone know of a dealer that sells the ECM retrofit motors in the USA.
Old 08-12-2010, 04:55 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 128
There are Emerson Eco Tech universal motors (ECM) non variable speed available in Canada. The variable speed ones are ONLY available OEM to furnaces as they have to be controlled by a specific brand of circuit board. Try Acklands Grainger.
http://www.emersonclimate.com/en-US/...e_ecotech.aspx
Old 08-12-2010, 06:54 PM   #7
An old Tradesmen
The Genteq is an Emersom ECM.
