Dayton Gas Furnace Burners Wont Stay Lit - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 05:17 PM   #31
Originally Posted by Yoyizit View Post
How much for a new amp? This seems to be a good candidate.
Dunno, is it built in with the circuit board controller? I believe most of them are all one piece flame safety equipment. see if you can find some numbers on the board that the flame rod is plugged into, I may be able to find you a decent deal.
Viper16 is offline   Reply With Quote
Old 10-06-2009, 08:50 PM   #32
Originally Posted by Viper16 View Post
there really isn't a way to over stress your flame rod...it is just metal material. i would bet there is poor signal quality or a flame amplifier is messed up/intermittent.
The flame light will light when there is a flame sensed from the rod, this will only light up once the other interlocks have been proved.
BTW, what other INTERLOCKS do you refer to?
hvaclover is offline   Reply With Quote
Old 10-06-2009, 09:54 PM   #33
The original post indicated there was a trouble code indicating a problem with a pressure switch connection. Also, you mentioned a damp basement. It is possible there is a crud build-up in the inducer housing assembly. Cannot say for sure, without being there. If one knows how to use a multi-meter, it is a great tool for troubleshooting just about any electric appliance. but, that is another topic.
Not saying this is a fix, but, it may be the cure: Take a paper clip, pull off the rubber hose that is attached to the inducer blower housing (at the housing) with the paper clip, (I know this sounds nasty) ream the nipple to clear out any possible obstruction. It is possible that the crud has blocked the suction outlet on the motor.
I have rarely had to replace a flame rod. Good luck
Flashheatingand is offline   Reply With Quote
Old 10-06-2009, 10:18 PM   #34
interlocks are air switches, gas pressure switches, temperature switches, and the flame rod amplifier has a switch in it that proves the flame when there should be a flame.
Old 10-07-2009, 08:51 AM   #35
Too loose an explanation for me. DI Or HSI prove flame or droppes out i n .80 seconds.
Old 10-07-2009, 09:06 AM   #36
This is true. I have not changed a flame sensor since my butter fingers dropped th existing one. And that was soo long ago I can't remember when it happened.
A paper clip is is sometimes too thick for the hose orifice on inducer motor,
I use a 1/16 drill bit with a cordless drill set to it's lowest setting carefully clean/ream the inducer orifice, and the press switch orifice, I carefully use a piece of stat cable and work it carefully around in the press switch orifice and then retry the furnace.
Old 10-07-2009, 09:10 AM   #37
lmkllm
Old 10-08-2009, 01:23 PM   #38
fixing ur problem
I have a dayton furnace, and if it is the 80% type (you will know what kind if it has a pvc or metal exhaust pipe). I had the same problem u have, and what it probably is a cracked heat exchanger. The furnace fires up and the flames are escaping into the plenum and is tripping the flame sensor.
Disclamer: if u try this I am not liable for personal injury or property damage.
info removed, please do not advise people to try something that may be dangerous
Master_01 is offline   Reply With Quote
Old 10-08-2009, 05:38 PM   #39
The mods should delete this post.
I don't know where this guy got this advice from (he might just be trolling)but it is not possible to jump a flame sensor. But to post anything that includes by passing necessary safety components is just plain
negligence.
This is not a cracked heat exchanger either so Master_01 does not know his head from his hind parts it would seem.
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 05:14 PM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 08:58 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
dayton furnace cycle prob. firefighter23 HVAC 4 02-01-2008 06:57 PM
