Dayton Furnace Issues When Switching Over To A/C - HVAC - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 09:21 AM   #1
Dayton furnace issues when switching over to A/C
Hello,
Some background...My Dayton furnace (less than 3 years old) had been working fine this winter for heating. Yesterday, I caved and turned on the A/C, which was also working fine last summer. I noticed that the condenser was not kicking on. I checked the furnace and it was throwing 5 reds, which the panel states as a 'Rollout Switch open/Fuse open'. This seems odd considering that I am using A/C and not the heat.
Troubleshooting that I've done:
1. Switched the break on/off several times (had breaker off overnight and turned on this morning to the same problem)
2. Bypassed the rollout sensors completely (note, this was just for a test. I know to never bypass sensors that could save your life someday)
3. Checked the voltage of the Yellow and Red wires from the stat on the main board. This states at 0 the whole time
4. Changed the stat batteries with working batteries
5. Completely pulled the thermostat from the wall
After number 5, the furnace unit still turns on when I turn the breaker on. Seems like something is completely wrong with this system. Could it possibly be the controller board?
Any other suggestions for troubleshooting this?
Thanks in advance,
Shawn
spar1977 is offline   Reply With Quote
Old 05-03-2012, 10:26 AM   #2
Rewards Points: 516
Maybe some help here?:
http://www.arnoldservice.com/air%20c...leshooting.pdf
diyorpay is offline   Reply With Quote
carrier/payne furnace heat exchanger issues gomongo1 HVAC 9 11-29-2014 08:29 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
oil fired furnace issues mrsbud Appliances 2 11-04-2009 04:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
dayton furnace cycle prob. firefighter23 HVAC 4 02-01-2008 05:57 PM
