Old 10-10-2011, 06:27 PM   #1
dayton furnace
my hanging dayton propane unit heater was running fine until i blew shop air into it to clean out dust. any thoughts on why it wont run now and how to get running?
martin88 is offline   Reply With Quote
Old 10-10-2011, 06:31 PM   #2
I'm Your Huckleberry
dayton furnace
Throw some dirt into it.
Doc Holliday is offline   Reply With Quote
Old 10-10-2011, 06:52 PM   #3
dayton furnace
Obviously I was kidding and now that the fun is over, you'd need to start from square one. You need to confirm everything is connected and that the gas valve is clear and working as well as the ignitor.
There sould be a service data plate on that unit for you to follow.
Old 10-10-2011, 06:57 PM   #4
biggles's Avatar
dayton furnace
check for 115v and 24vs connections might of knock a wire...spookypop the cover for the hi limit and the fan limit making sure the wires are landed
Old 10-10-2011, 08:49 PM   #5
dayton furnace
More than likely blew dust/dirt into pilot orifice. These holes are tiny any dust accumulation would obstruct it. Only way to find out is to pull it apart.
thestig3 is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 11 12-16-2012 07:18 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
dayton furnace cycle prob. firefighter23 HVAC 4 02-01-2008 06:57 PM
