Dayton 4xa48 Cabinet Wont Work Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 11:00 PM   #1
dayton 4xa48 cabinet wont work help
I have have a dayton heater i bought at an auction with a tank . i put a new regulator and line on it . after it runs 10 mins or so the regulator ices up and it starts acting up. would like if some one could stear me in the right direction to fix the problem
haywire0102 is offline   Reply With Quote
Old 03-10-2011, 05:37 AM   #2
An old Tradesmen
Rewards Points: 7,830
How big(in gallons) and how full is the tank? What size is the heater. Sounds like liquid LP is being drawn into the reg.
The Following User Says Thank You to beenthere For This Useful Post:
haywire0102 (03-10-2011)
Old 03-10-2011, 10:24 AM   #3
Its just a small bar b q bottle and its 2/3 full. But it did it full and close to empty.
Old 03-10-2011, 10:25 AM   #4
I think its a 5 gal tank
Old 03-10-2011, 05:06 PM   #5
An old Tradesmen
The heater is using more gas then that bottle is intended to supply. You need a larger bottle.
Old 03-10-2011, 06:46 PM   #6
It came with that bottle and it fits in the back side. Couls. There be anything else you can think of. Cause I've hooked it up to a 100# bottle and the hose and regulator still ice up.
Old 03-10-2011, 06:50 PM   #7
Rewards Points: 1,668
Is it possible it was NG and someone converted it to propane or vice versa and there is a regulator/orifice issue now?
bob22 is offline   Reply With Quote
Old 03-10-2011, 07:50 PM   #8
So do ya think I should take the orifice out and get one of the oposite
Old 03-11-2011, 04:19 AM   #9
An old Tradesmen
Take the orifice out and see what size it is. Then check a gas chart to see if its the right size.
Does the bottle sweat?
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 11:59 AM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 03:23 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
