Dayton 3E837 Unit Heater Manual - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 09:28 PM   #16
Rewards Points: 150
I also have the manual in .pdf if interested. It is for the 3E837, without any suffix. Just let me know.
TJ
TJ_in_IL is offline   Reply With Quote
Old 12-04-2009, 09:30 AM   #17
TJ if you could send that file to jim_brune at hotmail dot com I would really appreciate it. Tryingto get a similar heater going and having a time finding a manual.
Jbrune is offline   Reply With Quote
Old 12-04-2009, 10:15 AM   #18
Rewards Points: 150
Jim- file has been sent.
Old 01-14-2010, 11:08 AM   #19
3e837 manual
TJ, I would very much appreciate a copy of the manual file. I too am trying to get one going. email: "peytonbay at sbcglobal dot net".
peyton
peyton is offline   Reply With Quote
Old 01-14-2010, 11:41 AM   #20
Rewards Points: 150
peyton
Email has been sent.
Old 01-19-2010, 10:47 PM   #21
I just aquired the 3e837 and was wondering is you could send me a copy of the manual also. 86scottchevy at comcast dot net. i have no idea if it works and will be putting it up this spring. If it doesn't work I am more that willing to part it out.
86chevy is offline   Reply With Quote
Old 01-20-2010, 03:40 PM   #22
Rewards Points: 150
E-Mail has been sent.
Just an FYI.... this is a real old unit, and parts are really not available any longer.
Old 03-03-2010, 07:55 AM   #23
TJ_in_IL, I sure could use that .pdf file of the Maual for the Dayton 3E837 unit heater. You can email that to
That would be so helpful. Thank you in advance.
ajrNY is offline   Reply With Quote
Old 03-03-2010, 10:14 AM   #24
Rewards Points: 150
Is there a sufix to your model (A, B, C, etc)?
Information could be different between the different revisions.
Old 12-27-2010, 06:23 PM   #25
Dayton 3e837 Manual
TJ
TJ can you please send the manual to
Thanks.
Broken Stuff is offline   Reply With Quote
Old 12-28-2010, 08:15 AM   #26
Rewards Points: 150
@ Broken Stuff-
Email Sent.
Old 01-01-2011, 11:21 AM   #27
i would like get copy of manual. thanks
tstack is offline   Reply With Quote
Old 01-01-2011, 11:45 AM   #28
Rewards Points: 150
email sent
Old 02-05-2011, 03:50 PM   #29
TJ,
Can you send me a copy of the manual?
Michael
mswinton is offline   Reply With Quote
Old 05-02-2011, 09:39 PM   #30
Rewards Points: 18
Hi all,
My mom has a furnace which uses this therm-o-disc 29T12 to control the fan.
The failure is the wires soldered to a ceramic resistive-heater disk. The purpose of the heated disk is to keep the fan switch hot enough to stay on during the heating cycle. What happens is one or both wires pop free of the disk, result being the fan cycles on-off every few seconds.
The switch is repairable if you are handy with a soldering iron. Bend up the tabs on the rear of the switch and open it up. The tabs are brittle, so be careful and don't stab your finger! Careful wedging with a sharp screwdriver or short, stout awl on your multitool will get a bite under the tab and let you gently pry it up. Then use a good needlenose to bend the tab 90 so it clears.
Be careful to open the switch slowly as there are several loose parts that you need to note their orientation for correct reassembly. The curve of the click-disk points inward in case you forget! But it's a very simple design and easy to understand if you know a bit about electricity.
All you really need do is resolder the stiff, short wires to the ceramic heater disk. Only problem is, the wires are stiff and short, so working distance is small. The ceramic conducts the heat of soldering away from the joint, so it's very difficult to make a good connection. It usually works awhile, perhaps even a whole season, but inevitably it fails again for the same reason.
On my most recent attempt just an hour ago, I used a short jumper of thin copper tape that I got from Radio Shack, which is used to repair circuit board traces. That let me solder the jumper to the disk out in the open where I could get it good and hot (and not burn my fingers holding it!), then I soldered the other end of the jumper to the stiff wire. The copper tape is thin and self-adhesive, so I folded it over on itself to make the jumper. There is no room inside the switch for anything much more substantial than this.
Anyway, it seemed to hold well this time and is flexible enough that maybe it won't vibrate off or be cold-soldered as easily as the original wire connection.
The function of the switch can be checked with a continuity meter. I read about 170 Ohms or a little less on the heater disk (the two smaller terminals). The fan switch (two wide terminals) is normally open. Hold a lighter against the sensor and it will soon click, closing the fan terminals till it cools off.
Even if the assembly tabs break, the switch can still be re-used. After a few fixes, all the tabs on mine were broken off. I tied it back together through the mounting holes with some short bread ties. When you reinstall it, the mounting screws hold it together well enough to work.
Maybe that new conductive silver epoxy would work better than my method, or maybe the copper ribbon finally got it this time!
Even if you can actually buy this switch, it's still about $60, so a bit of time and solder is worth a try!
-Ed
Ed in SoDak is offline   Reply With Quote
Dayton gas heater ventureman HVAC 7 11-11-2013 09:11 PM
Help with Heater Unit BenJoeM HVAC 8 11-15-2008 05:16 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
