Dayton 3E226E Unit Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 07:46 PM   #1
Dayton 3E226E unit heater
I have this heater hung in my garage, plenty of clearance and 6 feet of vent stack.
The unit frequently "cycles out", meaning I have to climb up and push the reset button, then it operates fine for a few days and it happens again.
Thank you. John
6843 is offline   Reply With Quote
Old 12-01-2010, 07:55 PM   #2
HVAC / Plumbing
where is this reset button ? A pic would help
kenmac is offline   Reply With Quote
Old 12-01-2010, 09:34 PM   #3
kenmac,
The reset button is on the left side.
As looking at the left side, the reset is in the
top right corner. I stick my finger into a small
round opening and feel the button. Push it, hear a click
and the burner will fire up again.
Thank you.
Old 12-01-2010, 09:50 PM   #4
biggles's Avatar
if the unit fires up then the fan comes ON that limit has to be the hi limits with the red button reset..either it is weak on the metal disc and close to the fan ON disc from fatigue change it...the blades on the fan are clean and does the fan seem to be moving the normal air as usual..hi limit should pop at 200F-220F is the reset limit tripping with the fan running...if then its the HI LIMIT thats shot.
Old 12-01-2010, 09:56 PM   #5
sorry, yes, the fan continues to run, blowing cold, while the burner is off.
Click the reset, burner starts up, fan still running.
Thanks so much.
John
Old 12-02-2010, 10:03 AM   #6
Rewards Points: 150
From the owner's manual:
High Limit Switch p/n J11R00306-001
TJ_in_IL is offline   Reply With Quote
Old 12-02-2010, 11:03 AM   #7
HVAC / Plumbing
sounds like air flow issue
Tags
dayton , natural gas , unit heater
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 04:59 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 08:31 AM
Venting Water Heater near Central Air Unit rchrivera Plumbing 5 03-17-2010 12:03 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
