Day And Night Heater Blink Code 31 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 01:14 PM   #1
mlh
Day and Night Heater blink code 31
Can you tell me the proper steps for trouble shooting a code 31, have checked the heater box hose and it is not plugged. When you turn the heater on it will blink the 31 code but will not come on for about 15-30 minutes. Thank You
mlh is offline   Reply With Quote
Old 01-27-2008, 01:19 PM   #2
HvacWiz's Avatar
Rewards Points: 252
What brand of furnace do you have, carrier?
HvacWiz is offline   Reply With Quote
Old 01-28-2008, 03:26 PM   #3
mlh
Day and night blinl code 31
Ys I believe it is, nothing on the unit indicates brand
Old 01-28-2008, 06:44 PM   #4
Union HVAC Tech.
If it says Day and Night it's a Payne which is a cheap Carrier. Is the inducer fan running?
bigMikeB is offline   Reply With Quote
Old 01-31-2008, 04:53 PM   #5
mlh
day and night with blink code 31
When you set the temp at the thermostst you can hear a click and sometimes the inducer motor starts to run but only turns one revolution, then the code appears. If you remove the lower door and reinstall it the blower fan comes on for 60-90 seconds then goes off, after this if you adjust the thermostat up you hear the click and the inducer fan comes on and it starts and runs. Just a note: if the inducer fan is on and the igniter is starting to glow and you remove the rubber line from the inducer fan box to the vaccum switch the igniter goes out- reinstall the hose and the igniter gets hot and the heater lights, (inducer motor feels free and smooth).
Thank You, MIke
Old 01-31-2008, 10:32 PM   #6
Union HVAC Tech.
If you open the blower door the fan cycles because the power is turned back on, that's normal. You are also resetting the control module by cycling the power to the board. When you pull the hose off the pressure swithc is cutting of the power to the burner circuit, so that is working properly. If the inducer stops occasionally on start up, I would try and put a volt meter on it and see if the power to the motor is constant of if it's intermitent. If the motor has power but isn't on, it's time for a new motor. If the power is cutting in and out, the board is going.
The Veto propack, the Louis Viton of tool transportation.
Old 02-01-2008, 12:21 AM   #7
mlh
Day and Night blink code 31
What should the voltage to the Inducer motor be? 30V?
Mike
Old 02-01-2008, 12:57 AM   #8
HvacWiz's Avatar
Rewards Points: 252
120 v
