Data Communicating System. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 10:14 AM   #16
Willing to listen
Rewards Points: 223
Goodman customizes the airflow data for each model on the production line and stores it in the control board's shared data, so it's a little more precise than just a generic 400 cfm.
After the system autoconfigures you will have the option to go into the thermostat and trim the airflows +/- 10% in 2% increments, seperately for heat and cool speeds.
Also, you will be able to go into the thermostat status and query the CFM to see what it was auto configued to, or verify your trim adjustments if made.
Done That is offline   Reply With Quote
Old 10-27-2012, 05:58 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
No need to go in and do anything. Program pre-set from the factory, no trimming of anything on this end. I only set date and time, turned it on and easy peasy, like butter. Finally got it installed today, the 27th. Pics coming. Stat is pretty cool.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-27-2012, 06:11 PM   #18
An old Tradesmen
Rewards Points: 7,292
So you didn't adjust it to the load/needs of the house.
Old 10-27-2012, 08:40 PM   #19
I didn't know I was supposed to or had to. Explain please. Manual didn't say anything about how to know load. ??
Thanks.
Old 10-27-2012, 08:46 PM   #20
If you mean refrigerant charge than no I did not add. 60 degrees at intall ambient. I told customer id come back the first day they use a/c and charge to proper level. Not freezing low as it stands but low.
Thanks.
Old 10-27-2012, 08:53 PM   #21
Thanks.
Old 10-27-2012, 09:10 PM   #22
An old Tradesmen
No, I mean air flow for the latent and sensible load of the home.
Old 10-27-2012, 09:22 PM   #23
Explain how to find those loads and how to adjust accordingly.
Thanks.
Old 10-27-2012, 09:32 PM   #24
An old Tradesmen
A load calc of the house tells you your sensible and latent load. Then you match your indoor coil to your outdoor unit to meet those loads as close as possible from the equipment's spec sheets. And then adjust your blower speed up or down to get the SHR you need.
Here, I never run 400 CFM per ton, specially with VS blowers. Keeping the humidity low, makes people feel much more comfortable then just setting the temp lower.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (10-27-2012)
Old 10-27-2012, 09:35 PM   #25
No load for sure. Upstairs 3 ton installed, down 4 ton operational. In and out.
Thanks.
Old 10-27-2012, 09:43 PM   #26
An old Tradesmen
A shame. A good communicating system that could have been set up for great performance.
Old 10-27-2012, 10:34 PM   #27
Not a shame, $1500.00 less than usual price. Lifetime condenser replacement. I didn't charge labor for install and ate into my profit on top of that.
Help me if that's your intention, I'm all ears.
Thanks.
Old 10-27-2012, 10:35 PM   #28
I look up to you BT, you know this. Your words hurt when criticizing.
Thanks.
Old 10-27-2012, 10:46 PM   #29
An old Tradesmen
We all learn by doing. You missed your chance to learn on this job.
Any system that has a VS blower can be set up for good performance(if its not oversized). A simple load calc tells you the shr you need from it. The manufacturers all have spec sheets to pick a match that is close to what the house needs. And a minor adjustment to the blower speed/CFM brings the equipment closer to matching the homes load. By keeping the RH down, you often allow the customer to set their stat a degree of 2 higher. Helping to keep their cooling bill as low as possible.
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 07:18 PM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
