-   -   Damper motor has loose wires how to access? (http://www.diychatroom.com/f17/damper-motor-has-loose-wires-how-access-47909/)
g8rben 07-01-2009 04:38 PM
I have two zones connected to one heat pump. The upstairs damper motor has loose wires. If I jiggle the two red wires on the motor it will begin to spin, but I have to climb into the attic and do this about once a day. I can't see an obvious way to remove the small housing from the motor to access where the wires seem to be loose. Any help? :huh: The photos below are of the motor with the loose wires and the label on the main damper unit:
http://img.skitch.com/20090701-fp8jq...59.preview.jpg
Click for full size - Uploaded with plasq's Skitch
http://img.skitch.com/20090701-egb4w...s8.preview.jpg
biggles 07-01-2009 06:47 PM
might consider removing the motor off the damper or the entire damper housing and instasll a round piece till you can replace/repair it.that motor is not servicable with the wires going right to the windings...might be able to pop the cap on it down on a bench
