Damaged Fins On Furnace EVAP Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 10:18 AM   #1
Damaged fins on furnace EVAP coil
I pulled of the evap coil panel on my furnace today to get a real good look to see if I had a plugged up coil that was popping my limit switch a couple of times the last 2 weeks. I didn't see any dirt/dust that was out of the ordinary. However I saw that someone previously must have tried to service the coil or damaged it when it was installed. Im the second owner of the house for a year now. here is the damage to the fins
My evap coil setup is like this
the damge is a 2"x 3" area on this coil part
The damage is towards the front. I used a fine soft bristle hair come to straighten out what i could of the fins.
Is this enough to limit air flow?
My temperature within the first 2 feet of the supply plenum is about 130 degrees.
rlukas79 is offline   Reply With Quote
Old 12-21-2010, 02:52 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 180
Sounds okay. Subtract the return temp to get the temp rise Ie 130-70 = 60. Check the rating plate for allowable temp rise. You can carefully straighten those fins with a pocket screwdriver if you have patience.
Old 12-21-2010, 02:56 PM   #3
Yeah. it'll be fine.
hvaclover is offline   Reply With Quote
Old 12-21-2010, 02:58 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 180
Unlike my customer who took a pressure washer to his condensor coil.
Old 12-21-2010, 03:01 PM   #5
that was just not cool...
Old 12-21-2010, 03:10 PM   #6
40-70 is my heatrise. I may have just found out my short cycling problem, cracked inducer housing
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
replace AC coil along with furnace? js2318 HVAC 9 12-09-2009 07:51 AM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
