Cycle Time - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 06:25 PM   #1
Cycle time
What would be the minimum "on" time for a resi. HVAC system to properly remove moisture from the air?
On what does this time depend?
Old 06-29-2009, 06:51 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Does not exist. ACs are sized with heat infiltration rate and de-humidification is a bonus. A properly sized unit (not oversized) runs longer and does better de-humidification and so do 2 stage units but they are expensive.
Old 06-29-2009, 08:10 PM   #3
you right bruz Yuri!
Back in the day we used the ratio of 40% of the ACs capacity went to dehumidification before it did one bit of sensible cooling.
I was checking a unit to day that was low on gas in a 78*f 99%RH ODA.
Even though the low side was only 45psig the load was so heavy from humidity the head pressure was running close to 200psig.
hvaclover is offline   Reply With Quote
Burners quit during heat cycle kaw11 HVAC 4 01-24-2009 04:29 PM
Old Sryer Making Load Noise Thoughout Cycle. 68MHJCs Appliances 12 12-05-2008 07:51 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Furnace will cycle but not ignite ajpow365 HVAC 3 02-01-2008 09:57 AM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 06:46 PM
