-   -   Cycle time (http://www.diychatroom.com/f17/cycle-time-47765/)
Yoyizit 06-29-2009 05:25 PM
Cycle time
What would be the minimum "on" time for a resi. HVAC system to properly remove moisture from the air?
On what does this time depend?
yuri 06-29-2009 05:51 PM
Does not exist. ACs are sized with heat infiltration rate and de-humidification is a bonus. A properly sized unit (not oversized) runs longer and does better de-humidification and so do 2 stage units but they are expensive.
hvaclover 06-29-2009 07:10 PM
you right bruz Yuri!
Back in the day we used the ratio of 40% of the ACs capacity went to dehumidification before it did one bit of sensible cooling.
I was checking a unit to day that was low on gas in a 78*f 99%RH ODA.
Even though the low side was only 45psig the load was so heavy from humidity the head pressure was running close to 200psig.
