Cycle Lights Off A HW Boiler Stat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2013, 08:46 PM   #1
biggles's Avatar
cycle lights off a HW boiler stat
wired in the circulator and the hi limit to see the boiler and how it runs as the temps change.... ... hvac techs like to tweek systems
Old 12-20-2013, 05:08 AM   #2
An old Tradesmen
Rewards Points: 7,332
I'm guessing the timers to track run times are down at the boiler.
Old 12-20-2013, 07:08 AM   #3
biggles's Avatar
that was a thought....how about this trick coil up 3/4 soft copper like a giant truck spring.... slide it on the static flue pipe out of the boiler.pipe the return up to it with a 3-way valve and a TC-1 strapped to that return leaving the coil to pick up those BTUs going up the flue.good way to squeeze the last bit of heat out of a cycle...I won't touch that till spring if I ever get motivated.it would satisfy the burner TC-1 for sure,and just the circ.will run called from the house stat
Old 12-20-2013, 10:24 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... That sounds good in theory, but in real life it can bite ya, Badly,...
Robbin' All the heat outa the stack, slows or stops the gases Upward movement,...
Bondo is online now   Reply With Quote
Old 12-20-2013, 10:48 AM   #5
Rewards Points: 1,296
careful how much heat you pull out of the stack. Too much temp drop and you will start condensating the water out of the flue gasses.
danpik is offline   Reply With Quote
Old 12-20-2013, 03:10 PM   #6
An old Tradesmen
Condensation would be a concern.
Old 12-21-2013, 09:45 AM   #7
Rewards Points: 446
They already invented this..... it's called a condensing boiler. And they come with powered exhaust and use stainless steel venting or PVC. The powered exhaust to ensure proper draft and removal of flue gases from the unit and the SS and PVC because once cooled down to the condensation point, the moisture is very corrosive.
old_squid is offline   Reply With Quote
Lights on one circuit flicker now after tripping breaker shootmenow Electrical 8 04-13-2013 10:44 PM
lighting wiring diagram help, changed fan with lights to fan w/out and recesed lights snowmanZ Electrical 11 02-09-2013 05:38 PM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
