Cutting A Vent Into Basement Supply Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 07:24 AM   #1
Joel
Cutting a vent into basement supply duct
Can someone please tell me the best way to cut a register into a basement supply duct? I would like to cut a louvered 6" x 10" register into the supply duct in my basement to help add a bit of heat to the area. I probably want to trace the outline of the register on the duct and then drill four holes (one at each corner) of the rectangular pattern and then use a sheet metal sheers to cut out the sheet metal. What is the best drill bit for cutting into sheet metal, a step drill bit or a metal hole saw? What tools do I need and what's the best way to do this? Thanks in advance for any help.
Joel
jweiner is offline   Reply With Quote
Old 02-28-2009, 08:21 AM   #2
Rewards Points: 502
I typically use a metal hole saw and then go from there.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-28-2009, 10:18 AM   #3
An old Tradesmen
Rewards Points: 7,830
Actually.
If your going to cut the hole with aviation snips.
A flat blade screw driver and a hammer works best.
You make a long slot with teh screw driver and hammer, and then the snips make short work of it from there.
Old 02-28-2009, 12:56 PM   #4
tk03's Avatar
Rewards Points: 150
Just don't expect this to make a big difference in the basement air temperature. I would rather drop it to the floor and also grab a return.
tk03 is offline   Reply With Quote
Cutting through sill for dryer vent mjkpainting Building & Construction 13 06-05-2012 05:14 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
