Cutting Round Duct In Place - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 07:10 AM   #1
Cutting Round Duct in Place
Unfortunately I need to re route the 4" round duct that serves my dryer. I am going to have to open a few holes in my ceiling to pull this off, but I'd prefer not to have start from scratch.
I have cut round duct before, but only before it was rolled up. Any tips, pointers or suggestions for cutting round duct in place? I know I will need a crimping tool after I've cut it, but I'd like to figure out a way to get a passably clean cut.
Any thoughts?
Thanks!!
stubits is offline   Reply With Quote
Old 04-28-2010, 03:49 PM   #2
An old Tradesmen
Rewards Points: 7,370
In place in the joist cavity. Or just after its been snapped together?
Double cut snips. If you need to cut a section out. And want to be able to reuse both sections.
Old 04-28-2010, 04:13 PM   #3
Yes, I am talking about in place within the joist bay. And while it would be great to reuse the other end, it is not necessary. So, would these double edge snips work alright? How difficult is it to pull this off?
Old 04-28-2010, 05:58 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
If it is in place in the joist space snips won't work. I use a battery operated Milwaukee sawzall recip saw and a 6-8" metal blade.
Old 04-28-2010, 06:09 PM   #5
An old Tradesmen
To use snips. You have to remove the screws from the other end. So you can spin the duct.
Don't need double snips for that. Either regular snips.
Or a sawzall.
Old 04-28-2010, 06:26 PM   #6
Hvac Pro
yuri's Avatar
My new best friend. I like to treat myself to some nice tools to make my life easier once in awhile. Love this one. GREAT for cutting PVC pipe in tight places and repairs.
Old 04-28-2010, 07:06 PM   #7
An old Tradesmen
Looks like it makes short work of cutting pipe.
Old 04-28-2010, 07:49 PM   #8
Hvac Pro
yuri's Avatar
Cuts rebar, bolts and today it doubled for a tube cutter. Had to fix a job where a hacker company reused a line set and squished a 7/8 line down to 5/8 at the service valve. 3 ton unit won't run very well with a 5/16 liquid line either.
Old 04-28-2010, 08:02 PM   #9
OK, so since I don't have easy access to the ends of the duct, using snips isn't an option, right? But I can just use a metal blade on my reciprocating saw.
I have a standard reciprocating saw, do you think I'll be able to get a clean enough cut to re route the pipe?
Thanks!
Old 04-28-2010, 08:19 PM   #10
An old Tradesmen
If you can hold the pipe steady enough while cutting it, yes.
Old 04-28-2010, 08:29 PM   #11
Under the circumstances, there's really no better way, right?
Old 04-29-2010, 04:44 AM   #12
An old Tradesmen
Not really. Unless you want to redo all of that drywall.
Measuring and cutting ceramic tile around a round tub bdasilva Flooring 2 12-06-2009 09:33 AM
duct transition question masrapido HVAC 1 06-02-2009 07:30 PM
insulating duct work in basement Master Brian HVAC 10 05-19-2009 10:28 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
duct sizing Stu HVAC 2 12-22-2006 05:36 PM
