Cutting Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 08-01-2014, 08:18 AM   #1
Rewards Points: 874
Cutting duct work
I have to extend 3.25 x 10 duct from point A to point B. Problem is point A to point B is not a square/straight run, it is at an angle. How do I figure out what the angle is so I can cut the duct work to fit properly when installed? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 08-01-2014, 08:32 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,868
You don't. You get a angle transition piece made at a sheet metal shop and then attach the straight duct to it. That requires drafting and geometry or a skilled sheet metal guy to do.
Take a straight edge piece of metal and try measure the amount of offset and draw a picture and get a offset adaptor made. Or make a template from cardboard. then try and cut it from your new duct. Better to get an adaptor made.
Old 08-01-2014, 10:24 AM   #3
Rewards Points: 874
Thanks.No other way?
Old 08-01-2014, 12:11 PM   #4
Hvac Pro
yuri's Avatar
Not that I know of unless you want to get a piece of flex canvas connector made. It is neoprene nowadays but eventually will dry out and crack in 10 or more years.
Stay tuned if someone else has an idea.
Insulate duct work svaic00 Insulation 2 07-21-2013 10:19 PM
Advice for installing duct work for finishing basement captainj98 HVAC 1 05-11-2011 07:01 PM
New duct work design help!!! jmaville HVAC 15 04-22-2011 06:58 PM
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 07:29 PM
Tiger Foam On Duct Work atw58 Building & Construction 1 04-25-2008 10:25 PM
