Cutting Duct Before Or After Crimping - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 11:32 AM   #1
Rewards Points: 1,062
Question
cutting duct before or after crimping
this may be a stupid question but should you cut a duct with thin snips before or after crimping? one would think before but i find it that the snips can twist the crimping rail or groove or whatever you call it to the point of becoming uncrimpable. so then it would have made more sense to have crimped it before cutting and then cut it.
Old 03-03-2010, 01:53 PM   #2
I snap my round duct together. Cut to size than crimp.
hvaclover is offline   Reply With Quote
Old 03-03-2010, 02:11 PM   #3
30 year tech
hvac122's Avatar
As said, cut to size, put together then crimp.
hvac122 is offline   Reply With Quote
Old 03-03-2010, 02:14 PM   #4
Can cut first before you put it together too. But i think we both agree crimping comes after assembly.
Old 03-03-2010, 02:16 PM   #5
does "snap" mean fit the flat edge into the groove to make it round and "crimp" mean narrow one end to make it male so it can fit into the female ? because i am a little confused ...
in other words, do you cut when the duct is FLAT or when it is snapped together to be round ?
thanks
Old 03-03-2010, 04:04 PM   #6
An old Tradesmen
Rewards Points: 6,922
Cut it when it is flat.
If your snips are folding the metal over instead of cutting the metal. Either your snips are worn out, or the pivot screw and nut are loose. . Or they are low quality snips.
Old 03-03-2010, 04:11 PM   #7
thanks. that makes sense.
Old 03-05-2010, 05:04 AM   #8
At the ends of the ductwork where the female would accept the male into it...sometimes after crimping you might have to widen that area with a small screwdriver (not a lot) to widen it to accept the male end. After you snap the duct together I always slap the sides of the round....if it's not connected properly...it will pop apart. Then crimp it as the guys said above....good luck.
Affordable7 is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Cutting a vent into basement supply duct jweiner HVAC 3 02-28-2009 12:56 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
