Cutting Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2007, 09:46 PM   #1
ADKstorm's Avatar
Question
Cutting Duct
Was wondering what the best way of cutting ductwork. I need to cut a 6" diameter hole on top of my heat supply main to add one 6" offtake. I have looked at buying different types of snips but unsure what does the best job.
Is right cut mean just cuts right or does it also mean you need to use it in a certain hand? ...was thinking left hand would be logical and easier to cut right.
I came across this cutting tool today and was wondering if anyone has experience with it. One condition is I only have 8" of clearance between the duct top and subfloor.
The tool is: Klein Tools Nibbler Cutting Tool
http://www.acehardware.com/product/i...Id=21109859481
Not sure what the length of this tool is.
ADKstorm is offline   Reply With Quote
Old 05-17-2007, 07:44 PM   #2
Never seen or used that tool. But the best way to cut a small hole in the top of a duct that is installed is to do it through a large hole in the bottom of the duct. just patch the duct work when done.......trust me it may sound like a assinnine answer, but its the easiest way to do it, cut out the bottom of the duct reach up through and make your round hole then patch the bottom of the duct.If any one has a better idea i am all ears...........
harleyrider is offline   Reply With Quote
Old 05-18-2007, 10:05 AM   #3
People may oppose this but I am going to mention anyway:
if you have enough space to put an angle grinder into the 8" space you mentioned. You can use angle grinder to do the cuting with metal cutting blade (I used multipurpose blade before)... in term of effort... the angle grinder does all the hard work for you... in term of scary... this is the most scary method as a lot of fire work will come out when cutting... I did mine that way... and still alive and no burning house etc... the firework come out is not enough to burn anything... but you should wear eye mask and best is those wildering machine mask...
also in Canada, the hole we cut is rectangular... don't know why... but most HD duck pipes we sell here have rectangular opening converting to circular, and that make the cut even easier with angle grinder... Also, the metal wound from angle grinder is the most prettiest compare to other type of device cutting
KUIPORNG is offline   Reply With Quote
Old 05-18-2007, 03:57 PM   #4
Home Improvement Guy
ron schenker's Avatar
I'd be wounded too if I cut duct with an angle grinder
ron schenker is offline   Reply With Quote
Old 05-18-2007, 10:57 PM   #5
Malco makes an awesome circular hole cutter. It can be adjusted to cut different diameters of holes. It attaches to a regular power drill. They also make an angle attachment which makes it great for spaces like your talking about. I've seen the cutters at Ace Hardware and home depot. They are a bit pricey, so you may want to check with a HVAC supply store to see if they can rent one to you. Good luck.
www.malcoproducts.com
Rookietinner is offline   Reply With Quote
Old 05-18-2007, 11:01 PM   #6
Rewards Points: 1,088
You can use a jig saw.
handy man88 is offline   Reply With Quote
Old 05-19-2007, 09:39 AM   #7
ADKstorm's Avatar
Thumbs up
nice
These would work perfectly, except the price is very high for me when I only would need them to cut one 6" diameter hole. I would probably buy one if it also cut holes into wood, but seems it is only for sheetmetal applications.
Thanks for the info anyway!
Old 05-19-2007, 09:41 AM   #8
ADKstorm's Avatar
A jig saw on sheet metal duct? Seems like the up and down action would cause problems....and I would never be able to fit one in the tight space.
Thanks anyway for the idea
Old 05-19-2007, 02:59 PM   #9
Rewards Points: 528
With only 8 inches of clearance, I would use a hole cutter. If you try to use snips, you will find that you must hold the tool upright to the cutting area for it to work well and you still must be able to see how well you are cutting. You may have looked at an expensive hole cutter. Look around for a cheaper model.
I don't know what you call expensive but I have tools that I only used once since I bought them and if I tried to use anything but the right tool, I would have butchered the job.
Another option would be a "hole saw". I have one that will cut a 6 inch hole. You will probally need an angle adapter for your drill.
rjordan392 is offline   Reply With Quote
Old 01-23-2011, 01:04 AM   #10
you can also use a dremel tool, works in small/tight spaces,and works well and is versatile.
dccatfan is offline   Reply With Quote
Old 01-23-2011, 01:30 AM   #11
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Jesus this thread is hilarious!
unicursalhex is offline   Reply With Quote
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 03:22 PM
duct sizing Stu HVAC 2 12-22-2006 05:36 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 08:28 PM
