Customer Hates Noisy New Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 07:42 PM   #1
Rewards Points: 99
Customer hates noisy new furnace
Just installed a new goodman 80k furnace in customers house.
Customer called today complaining about how noisy the new furnace is compared to her old Gaffers and Sattler. The furnace is in the standard closet location in the hallway and apparently the noise is just the standard jet noise from the burners which I explained is inherent in all the 80% furnaces.
Her hardwood floors are not helping either.
Can anyone recommend some type of material to line the closet walls to insulate the noise?
Thanks a lot
kirwinjd is offline   Reply With Quote
Old 02-08-2013, 07:47 PM   #2
MarginallyQualified
Rewards Points: 2,464
"They all do that ma'am"
Is the bill paid?
The Following User Says Thank You to TarheelTerp For This Useful Post:
gregzoll (02-08-2013)
Old 02-08-2013, 08:08 PM   #3
Roofmaster
Rewards Points: 2,172
Foam Rubber...............Earplugs
Old 02-08-2013, 08:18 PM   #4
concretemasonry's Avatar
Rewards Points: 2,566
Could be a bad install with vibrating sheet metal.
Have looked and felt everything? - Vibrations can be cured as long as you understand the harmonics of tin.
Dick
concretemasonry is offline   Reply With Quote
Old 02-08-2013, 08:31 PM   #5
An old Tradesmen
Rewards Points: 6,060
Where does the combustion air come from.
Old 02-08-2013, 08:52 PM   #6
Rewards Points: 582
what is the gas pressure..some times installing a regulator setting manifold pressure to 3.2 will quiet the inshot burnners down for closet installation...ben sr
Old 02-08-2013, 09:43 PM   #7
Rewards Points: 99
Dick
It's not a bad install but thanks anyways. Everything is tight. It's a brand new furnace and its running as smoothly as the other 25 + I installed last year. Everyone is different and most people are ok with it. I do get the 10% of customers who are noise sensitive and it may not even be the level of noise but a different noise. People are so used to the old furnace for 30 years, they no longer hear it
Old 02-08-2013, 09:55 PM   #8
Just because everything is tight does not make it good. Vibration and harmonics can get complicated and frustrating. Often, it can cause noises and in some cases some isolation can reduce the noise from everything attached to the furnace unless you want do do ductwork modifications. I had a rock solid professional furnace installation and discovered the noise were from the ductwork vibrations of the ducts. - I eliminated much of the noise with a bungee cord tight around a major duct and tied it up to a joist to change the harmonics and the cord was a spare and was uded in my utility room.
Dick
Old 02-08-2013, 10:03 PM   #9
Rewards Points: 99
Dick
Thanks again and your absolutely right about the issue of harmonics. It can be complex. What the customer is complaining about is the sound of the flames being jetted into the burners vs the old ribbon style burners.
Old 02-08-2013, 10:08 PM   #10
Rewards Points: 99
Thanks for the advice. Sounds like a good idea. I'll check it.
The Following User Says Thank You to kirwinjd For This Useful Post:
ben's plumbing (02-08-2013)
Old 02-08-2013, 10:11 PM   #11
Rewards Points: 99
Combustion air coming from attic screen above.
Old 02-08-2013, 10:19 PM   #12
Rewards Points: 1,192
I hear Nothing!
bobelectric is offline   Reply With Quote
Old 02-08-2013, 10:27 PM   #13
Rewards Points: 99
Originally Posted by bobelectric
I hear Nothing!
I wish lol But with that attitude, I'll also not hear my phone ring from customers who don't call contractors with a bad reputation
Old 02-09-2013, 05:57 AM   #14
An old Tradesmen
1 inch duct board glued to the walls and door, or 1 inch thick duct wrap glued to the walls will reduce the amount of noise.
Foil side toward furnace.
Old 02-09-2013, 09:46 AM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Dropping the manifold pressure to 3.2
Personally I would never do that as you risk the chance of delayed ignition. inlet pressure can vary but outlet pressure should always be 3.5. dropping the pressure reduces the velocity/speed of the gas and may change the timing of how fast the crossovers work or even the angle of the gas hitting the igniter. carrier and rheem have some issues with velocity thru the burner box and ignition patterns so I would not go there. problem may occur when new and probably will occur a few years from now when the burners get dirty or rust/corrosion on the ends of them which is unavoidable.
Duct insulation attached to the door and walls of the closet would be my choice. Check the manifold pressure anyway as it may be above 3.5 and overfired. seen that happen a lot.
Gas Furnace Replacement Questions mark2741 HVAC 31 01-17-2013 01:15 AM
lint/dust from furnace uksparky HVAC 15 02-16-2012 06:01 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
