Curiosity, How Much Oversizing Till It's 'felt' - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 05:09 PM   #1
Rewards Points: 150
Curiosity, How much oversizing till it's 'felt'
This is just a question of curiosity, I understand the importance of sizing ac tons correctly for your home, but how big is too big to label it ' over sized ' and you actually start feeling the hurt with your air quality and short cycling?
Half ton over?
1 ton over ?
if a house is calling for 2.5 tons on a manual J calc, and a 3 ton is installed for example.... I mean, it's only a measly 6000 btu's right?
Just trying to ease my curiosity of how much is toooo much.
Thanks.
alecmcmahon is offline   Reply With Quote
Old 05-01-2011, 05:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
1/2 ton will do it. Causes shorter cycles and less dehumidification.
Old 05-01-2011, 07:26 PM   #3
An old Tradesmen
Rewards Points: 8,142
A half ton larger unit. When the indoor temp is 80F dry bulb and 67F wet bulb with the outdoor temp at 95F, its only a measly 6000 btu's.
When your indoor temp is 80F dry bulb and 67F wet bulb with an outdoor temp of 85F, its about 16,000 BTUs over sized.
When your indoor temp is 80F dry bulb and 67F wet bulb with an outdoor temp of 75F, its about 28,000 BTUs over sized.
An over sized unit will cause most people to have to set the thermostat to a lower temp ( 2 to 4 degrees lower ) to feel as comfortable as they would why a properly sized unit using far more electric.
leaking felt puppyzeus Roofing/Siding 25 06-14-2013 02:27 PM
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Felt for Reinke Alum Shakes SCDome Roofing/Siding 1 09-26-2009 01:53 PM
Roofing over old felt!! bandit55 Roofing/Siding 65 06-03-2009 11:44 AM
How do I attach the 15# roofing felt to the subfloor? rncopper Flooring 8 06-23-2008 09:17 PM
