Crown Oil Furnace Short Cycling - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2008, 07:07 AM   #1
Rewards Points: 77
Hello, I've got a 4 year old Crown oil fired hot water furnace thats short cycling. Its got 3 zones, basement, bedroom and main living area. The limits are set at 180 high and 160 low. The unit was just serviced a few months ago and it seemed to get a little worse after the service. I'm not sure if he adjusted the limits and made it worse. We've only owned the house for just a year so I can't give you an idea of how it was before. We've got one programable thermostat and 2 mercury thermostats. Any info is greatly appreciated. Thanks.
GearHd6 is offline   Reply With Quote
Old 02-28-2008, 08:54 AM   #2
Learning by Doing
Leah Frances's Avatar
http://www.heatinghelp.com has some great resources and good pros on the "Wall" post there, and I expect you will get some good suggestions.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-28-2008, 10:21 AM   #3
Rewards Points: 77
Any clue where on that site I might find info about my heating problem? I notice you said "Wall" but i'm not seeing anything like that. What am I missing? Thanks again.
Old 02-28-2008, 10:38 AM   #4
Learning by Doing
For reference http://www.heatinghelp.com
At there is a 'Questions' link in the main banner. For some reason they call it "the Wall". The 'Search' tool in the orange banner [Exit New Message Search Options] is a great tool for finding germane information.
To post a new thread
1. Click "New Thread";
2. Insert a Topic (Crown Oil Furnace Short Cycling ) works just fine;
3. Select "The Wall" for Heating questions;
4. Fill in the "Post Question" Form;
5. Wait for responses.
The more information you give the better. But beware of getting long winded (good advice, eh?).
caveat: everyone will recommend you get dan Holohan's books about steam heat and boilers. Prepare yourself for it.
PS. For some really technical stuff check out and post at http://www.boilerroom.com/homeforum.html. They really really know their stuff.
Happy Heating
Last edited by Leah Frances; 02-28-2008 at 10:41 AM. Reason: To add search function advice
Old 02-28-2008, 10:53 AM   #5
Rewards Points: 77
Hey, thanks. That was a little tricky to find, thanks for the guidance and thanks for the heads up on the book recommendation.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 10:58 AM
HVAC Short Cycling Redparis HVAC 2 02-26-2008 10:21 PM
Burnham furnace short cycling ademaggi HVAC 2 02-13-2008 03:51 PM
furnace cycling / shut down Snailspace HVAC 12 02-04-2008 09:08 PM
